Cranking
Old May 7, 2025 | 03:14 PM
B Lucas's Avatar
B Lucas
8th Gear
Default Cranking
Why when I crank my car. It turns over twice, stops for a few seconds the cranks up.
2009 c6 corvette base
Ls3 engine
TIA
Brand new battery
Old May 7, 2025 | 03:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you have a DVOM I’d check the battery voltage just to see if it’s fully charged…12.66 for lead acid and 13.00 for AGM…also make sure the battery cables are clean and tightened securely…always start with the battery.
