Regarding Gas...
Costco ipays for the top tier gas label.
Even the cheap stations of gas have better additive packages today than the best did when the C6 was new. Don't worry about it.
Also, the use of EPA standard gas with a can of Techron (or other additive) now and then is not as effective as consistent use of Top Tier. The best analogy I can think of is your laundry washing machine. Do you suppose using half the recommended dose of detergent most of the time, with an occasional triple dose will keep your clothes as clean as using the recommended dose all the time? And keep in mind that on your triple dose day, the extra detergent might not get completely rinsed out of your clothes. It’s possible both with clothes and cars to build up deposits from residual detergent.
Finally, while I admit that I don’t know what “ipay” is, I can tell you that Costco and other Top Tier brands do not simply pay for a label. Almost all the cost of Top Tier is the cost of the better performing additive packages that are required to meet the Top Tier cleanliness standards. The fee paid to Top Tier is trivial, and simply covers the cost of administering the program. So if the gas is not Top Tier, you can be 100% certain that its additive package does not perform as well as a Top Tier package does.
Note that none of the above says your engine will be ruined by EPA gas. It is a good standard, just not a great one. I’ll guarantee basis having seen the torn down test engines with my own eyes, that if you run an engine in a test cell for the equivalent of 50,000 miles on Top Tier versus EPA gas, the internals of the engine run on EPA gas will not only be measurably dirtier, it will even be visually dirtier to the eyes. Ruined? Of course not. Running as close to showroom-new condition? Also, of course not.
The testing for top tier gas is easy, you can look up the standard. It's based around an old Ford motor with a design flaw that causes the valves to get dirty.
A modern, well designed engine like an LS isn't prone to valves getting dirty anyways. Let alone with modern additives.
Project Farm tested this all and found no measurable difference.
As to intake valve stems, they are less of an issue with direct injection anyway, since in most DI engines, fuel does not contact the intake valve stem. But that leaves injectors, plugs, combustion chambers, valve faces, and piston crowns, all of which collect deposits.
There are quite a few Top Tier skeptics on the forum and you are obviously one of them. But I’ll stick with what I said in post #14 and this post, because I’ve seen carefully controlled, long term tests on real car engines with my own eyes, and I trust them over quickie lawn mower engine tests and/or internet scuttlebutt.
I got in the habit of adding techron annually after some experienced issues with level switches in the tanks getting dirty and it seemed to help.
