MAF Sensor 2011GS
Old May 23, 2025 | 07:13 PM
3X BLK's Avatar
3X BLK
Default MAF Sensor 2011GS
I’m confused about cleaning my MAF. All of the videos I see on YT seem to be for MAF’s that are composed of three wires stretched across round intake part. My MAF (for lack of a better description) looks similar to a large thumb drive 🤪. There is on short video out there that shows a young man spraying MAF cleaner into several holes in the sensor? There is a sticker by the sensor that advises not to remove it and it is not serviceable. Thus my confusion. TIA for any advice.
Old May 23, 2025 | 08:15 PM
crusher1's Avatar
crusher1
On my 07 I have the wire element style and use CRC MAF cleaner every spring. You have the card style MAF remove the card from the intake and clean it. Heres how to clean it. See vid below
Old May 23, 2025 | 08:54 PM
3X BLK's Avatar
3X BLK
Thanks! The video you sent was the one I mentioned in my post-seems to be the only one is why I was worried it might not be advisable to clean it.
Old May 24, 2025 | 11:46 AM
dawizman's Avatar
dawizman
You're fine using a proper sensor cleaner. Definitely something to do regularly if you are using an oiled air filter.
To MAF Sensor 2011GS
