Quick assist please
Old Jul 12, 2025 | 05:15 PM
BlackFya's Avatar
BlackFya
Default Quick assist please
Folks I have a 1LT 08 coupe. I’m installing a set of 2013 3LT heated dual power seats. Aside from the heat function not working, should there be any issues with the seat adjustment functions working on the passenger seat? It was previously non powered. I connected both connectors. No power options right now
Old Jul 12, 2025 | 05:34 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Did you check fuse block, being 1LT might not have fuses in the slots.
Old Jul 12, 2025 | 06:03 PM
BlackFya's Avatar
BlackFya
good call… it did not. Gotta grab some spares anyway.
Old Jul 12, 2025 | 07:01 PM
BlackFya's Avatar
BlackFya
Default No luck….
I put that fuse in and checked relays/fuses for everything related to seats… still now power to passenger seat
Old Jul 12, 2025 | 08:55 PM
BlackFya's Avatar
BlackFya
I thought these were quick plug and play. Didn’t know the seatbelts were different. The newer model is smaller and won’t allow it to secure
Old Jul 13, 2025 | 11:14 AM
FatsWaller's Avatar
FatsWaller
According to this, you’ll need to run a new power line to the passenger seat https://www.corvetteforum.com/forums...post1599067192
Reference is for Z06/ZR1, but the wiring harnesses and fuse panels should be mostly the same.
To Quick assist please
