Lowering C6 stuck bolt
You've probably already seen youtubes or notes about how the ride height adjuster threads into a threaded sleeve epoxied into the spring. If you heat it to loosen it, you run the risk of loosening the epoxy but that's repairable by re-epoxying the sleeve into the spring.
I tried using a pipe wrench to loosen mine but ended up trashing the rubber pad on the ride height adjuster. I eventually removed the spring and used the vice holding the adjuster with lots of WD and penetrating oil and it came loose - no damage to the sleeve or epoxy. The length of the spring makes a nice long lever to put lots of torque on the adjuster.
Chevy doesn't carry the replacement leaf spring, so it seems that buying used or the epoxy repair is the only way to fix the loose sleeve problem at this time.
This is the replacement ride height adjuster that I used. It has the correct thread pitch for the C6. I used a pair from a well-known Corvette house that had the wrong pitch. Ended up tossing them.
Hope it helps!
The first one, I put a pipe wrench on the lower part of it and broke it off. Put the pipe wrench on the metal lower portion of the insert and it ended up walking out of the spring.
I put that one in a vice and heated the bolt up, then melted candle wax into it and it came right out. Pressed the insert back into the spring and screwed in the lowering bolt.
Next one, I tried heating it up while it was in the spring and melting the wax down into it. I don't recommend doing this. I think the heat was going into the fiberglass spring and damaging it, so I stopped. I got out my air hammer and walked the rest of the bolts out this way. This does end up damaging the OEM bolts. I didn't worry about that because I had new lowering bolts.
Hope this helps.
Hope this helps.
