Coolant question
I already have some work scheduled and thinking of having the coolant done at the same time. So, what's the current consensus: Dex-Cool : Good? Bad? Better than Prestone? or Not. Use Dex-Cool or Prestone Green?
As for dex cool change, you want to replace the T stat at the same time. So remove R state, put filler neck back on without T stat, fill system with distalled water, let engine run for few mins, dump out that distalled water, do it again, and this next dump out, look at the color of the water, and it still on the dirty side, do it again with distilled water and running for a few mins again.
Now with that dumped out and water coming out clear, install new T state with it weep channel/device in flange top dead center, fill system back up with reserve tank to full mark (the line is on the front side or tank (tank will be about half full, when full), start the motor, and put a vacuum on the reserve tank to pull any air still in the coolant system, then top tank back up to full mark.
As for vacuum device, standard vacum brake bleeder pump, and rubber cone plug that fits the id of the tank fill bunge for pump to pull vacuum in, will work fine.
