Exhaust Question
I would hate to have to pay to get it to him twice, so I'm wondering if there are any x-pipes out there that are readily available that fit these two items?
Also, is it normal for this size discrepancy?
If you really want it tuned, just wait until the mid pipe is in place.
The sizing is all common sizing. No issues there. Everything is bolt on
Awesome, thank you. I feel like everywhere I've been looking, the mid pipe is unavailable or on back order, lol.
Why would one want to drive the car without an exhaust to a tuner to tune?
either way, if he tunes on stock exhaust, the tune is not going to change with longtubes, so either way, it’s a non issue
http://www.corvetteexhaustsystems.com
sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
Do you NEED a tune after catted long tubes? No. Do you NEED a tune after non-catted long tubes? Probably.
SHOULD you tune after any set of long tubes? Absolutely.
Your short/long term fuel trim could probably make do with the current tune and perform the fueling corrections needed. You probably wouldn't pick up any timing with long tubes, so your ignition tables would likely stay the same.
But with that being said, your airflow out changes along with a slight change in efficiency at different points of the rev range due to the helmholtz effect. Optimum RPM directly correlates with runner diameter and length, and that goes for intake and exhaust. If you change either, you should at lease do some datalogging to check and make sure everything is still how you want it WITH YOUR FUEL TRIMS OFF. That way, if one of your injectors ever starts to spray less, or any other issue arises, your fuel trims can help account for them.
In response to the OP's question, I'd either find another x-pipe that fits, or have an exhaust shop make the headers fit up to the factory midpipe. Any midpipe will be close enough to whatever you ordered, you just need some length of pipe on there with a crossover between the two, even if it doesn't connect to the mufflers. Mufflers are pretty negligible.
If you're in a place where you have to pass emissions, I've had good luck with O2 extenders in my last car with long tubes (s550 mustang), but have yet to do headers on my C6 GS.
How does every tuner turn off the cel them if they are not turning the sensors off? I can promise you they aren’t installing extenders.
I am telling you they turn off the 02 feedback on the rear o2’s. Lol.
PS: window tint is not a safety check atleast in PA. It’s illegal, but it’s not a safety check that would get flagged for inspection.
This is probably another one of those internet myths things like tuning with headers.
Your fuel trims do not change due to lack of catalyst. If they did, it’s by such a minute amount, it’s not worth discussing.
