Power Steering Issue
Old Aug 8, 2025 | 08:35 PM
JustinM1048's Avatar
JustinM1048
3rd Gear
Default Power Steering Issue
I got a 13 Grand Sport and sometimes I will get the "Service Vehicle Soon" message and my power steering ceases to work. However after a week or two it vanishes and my power steering returns. This cycle happens non stop and I cant find any pattern that would cause this issue. Power Steering liquid levels and fine with no leaks. Maybe a electrical issue?
Old Aug 8, 2025 | 08:44 PM
FatsWaller's Avatar
FatsWaller
Might be the EBCM. Here’s a discussion from this forum https://www.corvetteforum.com/forums...ss-of-p-s.html
Old Aug 8, 2025 | 08:52 PM
Corvettechris86's Avatar
Corvettechris86
Mine does the same and it doesn’t throw any codes, only thing i’m seeing is a code for the tail lights after switching to led tails. Could be that causing it in my case…
Old Aug 8, 2025 | 10:02 PM
JustinM1048
3rd Gear
After reading that it makes so much sense, thanks!
Old Aug 8, 2025 | 10:03 PM
JustinM1048
3rd Gear
Mine does not either, you should read that link the other comment replied with, I'm 99% sure that's my issue.
Old Aug 9, 2025 | 08:07 AM
seijack's Avatar
seijack
What does the EBCM stand for?
Old Aug 9, 2025 | 08:35 AM
FatsWaller's Avatar
FatsWaller
Electronic Brake Control Module
I’m only pointing the OP to a thread where it turned out to be the culprit. I think I pulled up a few more threads that were similar.
To Power Steering Issue
