Engine swap
Old Aug 20, 2025 | 11:34 AM
Poppa0807's Avatar
Poppa0807
2nd Gear
Default Engine swap
My 2006 C6 base manual needs a new motor. What engines (6L or 6.2L) can I use? Also does it need to come from a manual transmission as that is what is in my Vette?
Old Aug 21, 2025 | 09:17 AM
DarkC-6's Avatar
DarkC-6
You can use pretty much any Gen4 LS engine. Doesn't matter if it came from a manual or auto vehicle.
Old Aug 21, 2025 | 09:21 AM
PMPerformance's Avatar
PMPerformance
Pretty sure an LS9 is your only option
Old Aug 21, 2025 | 09:51 AM
ClothSeats's Avatar
ClothSeats
If you want to avoid a custom tune, you may want to stick with an LS2. I'm not sure about that, though. Maybe someone else could comment on running an LS3 with an LS2 stock tune.
Old Aug 21, 2025 | 12:14 PM
hcbph's Avatar
hcbph
This is just 'thinking the issue trough' so take it as that. If you have a stock LS2 and replace it with a stock LS2 then everything should hookup and match. It would IMO be as close to a 'plug and play' as you could get. Hopefully it will work out. By the way, are you sure the old engine needs replacing or could it be rebuilt?
Old Aug 21, 2025 | 05:48 PM
z06801's Avatar
z06801
In for the info on this I need to buy a pull out for my c6 roller.
Old Aug 21, 2025 | 05:54 PM
jbc1995fb's Avatar
jbc1995fb
just curious of how many miles were on the engine? I suppose you're going to take it somewhere to get installed?
I'm thinking the OP is confused because the GS - LS3 that had the dry sump with the manual transmissions.
Old Aug 23, 2025 | 09:25 AM
RoadkingC6's Avatar
RoadkingC6
just a question on a car that came with an automatic transmission, is the crank drilled for a pilot bushing ?,
To Engine swap
