2007 Clock Spring
Old Sep 3, 2025 | 07:48 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Default 2007 Clock Spring
Hopefully a quick question: Planning on swapping steering wheels soon. My 2007 has radio controls on the right but no bluetooth on the left; do I need to change clock springs to support bluetooth? Thanks!
Old Sep 3, 2025 | 10:45 AM
madsonp's Avatar
madsonp
Shouldn’t have to.
Old Sep 3, 2025 | 10:50 AM
DrKrieger's Avatar
DrKrieger
Nope.....
Old Sep 8, 2025 | 02:22 PM
ominousone's Avatar
ominousone
Not to high-jack this thread, but I have a, sort of, related question. My '06 C6 Coupe doesn't have radio controls on the steering wheel. Is there wiring so I could get another steering wheel with the controls and swap. OR would it be a huge PITA?
Thanks.
Old Sep 8, 2025 | 02:35 PM
madsonp's Avatar
madsonp
Thanks.
What are you running for a head unit ? If it’s a stock radio or nav system, it’s not going to be able to be controlled by the steering wheel controls, you’d either need to get a newer 2008+ stock nav system, or go with an aftermarket system. Then you’d have to get a 2007+ clock spring and run three new wires, not really that difficult, see this attachment, contrary to what the attachment says, your current air bag should work fine with this mod.
File Type: pdf
Old Sep 8, 2025 | 03:53 PM
ominousone's Avatar
ominousone
Thank you madsonp.
Old Sep 8, 2025 | 04:25 PM
madsonp's Avatar
madsonp
Thank you madsonp.
Glad to help.
To 2007 Clock Spring
