Power steering pump problem
Old Sep 8, 2025 | 12:37 PM
rhandle's Avatar
rhandle
Default Power steering pump problem
I have a 07 Z 51 C6. I’ve recently been having problems intermittently where the power steering would harden up as I am trying to make a turn in the parking lot. It doesn’t always happen, but when it does, it’s very difficult to turn the steering wheel. There are no unusual noises coming from the pump and the steering fluid is full. if the power steering pump is failing, are there any additives that could be added to the fluid to relieve this problem. Most of the time I would say 90% there is no issue with the steering.Thank you in advance.
Old Sep 9, 2025 | 01:24 PM
Dano523's Avatar
Dano523
Let me guess, when power steering fluid/pump is cold,
and/or idle RPM's dropping down below 600.
Start by checking power steering fluids (low or burnt, or someone used the wrong type), double check the steering rank connector for corrosion problems, and .if still a problem with system warmed up, then bump idle RPM's up about 50 rpms if it has a tune on it with either HP tuner or EFI live. If no tune, and car is idling less than 550, the could be time for a tune, or just cleaning the maf sensor, new air filter may solve the problem instead.
Simply, watch your RPMs, and if lower than say 550 when steering is going hard, that's your problem with pump just not spinning fast enough to create the needed pressure to the rack. If above that for rpms, then pump should be putting out enough pressure (if nothing wrong with it and fluid), and maybe rack connector problems isntead.
Old Sep 10, 2025 | 03:43 PM
rhandle's Avatar
rhandle
Thanks Dano! What Fluid do you use??
Old Sep 11, 2025 | 12:52 PM
Dano523's Avatar
Dano523
ACDelco 10-5073
Other brands of synthetic power steering fluid are acceptable, but confirm they are suitable for GM vehicles, like Red Line Synthetic Oil, Lucas power steering fluid, and Valvoline MaxLife. Do not use conventional power steering fluids.
Old Sep 11, 2025 | 05:54 PM
glenx122's Avatar
glenx122
Check your ABS sensors and wiring harnesses.
A similar issue was brought up at Carlisle during the diagnostics Q&A.
Old Sep 11, 2025 | 08:54 PM
rhandle's Avatar
rhandle
Why can't I use "conventional power steering fluid" like you said? I thought that conventional is OEM factory fill?
Old Sep 12, 2025 | 08:56 AM
DarkC-6's Avatar
DarkC-6
I just used some Prestone that said it was compatible with GM vehicles from the local auto parts store. No issues at all.
Old Sep 12, 2025 | 09:06 AM
dr_gallup's Avatar
dr_gallup
Originally Posted by Dano523
ACDelco 10-5073
Why does Amazon tell me ACDelco 10-5073 is not right for my '13 GS and I should get ACDelco 10-5074?
Old Sep 12, 2025 | 07:54 PM
kestell123's Avatar
kestell123
Another thing to consider is a problem with the variable effort steering. There is a pindle valve in the steering rack that control steering effort by speed , easy steering at low speeds, more effort at higher speeds. This system gets input from the EBCM. In my case the problem was a broken wire in the EBCM plug caused by to much tention on the wire.
Old Sep 20, 2025 | 11:15 PM
rhandle's Avatar
rhandle
WAIT A MINUTE ! Does the C6 use Synthetic Power Steering Fluid? Or conventional. I bought ACDelco 10-5073 . Amazon describes this as "MINERAL OIL".
So I didn't put synthetic in? Could that cause hard steering. If I was supposed to use synthetic,how do I get the conventional stuff out of the rez?
Old Sep 21, 2025 | 09:05 AM
vinny R's Avatar
vinny R
if you had non synthetic fluid in the system you should not add synthetic fluid and mix both. OEM is conventional oil. They aren't really compatible and if synthetic is what you want you need to do a fluid swap. You should do a fluid swap anyway as I had a similar issue and once the fluid was changed my problem was gone. I used the Prestone PS fluid and no issues.
I did a "ranger" method where I used a brake bleeder vacuum pump to pump out the rez, refill with fluid, start car, turn wheel to full lock both directions a few times and repeat. Do this until the fluid is clear. I went through 2 quarts. The fluid I removed the 1st time was muddy water brown and had a pungent burnt smell to it.
Old Sep 21, 2025 | 09:11 AM
dr_gallup's Avatar
dr_gallup
AC Delco also says that's not the right fluid. They say to use ACDelco Part # 10-5074. I have no idea what happens if you mix them.
Old Sep 21, 2025 | 10:43 AM
Pete79L82's Avatar
Pete79L82
10-5073 is 32oz bottle. 10-5074 is 16oz bottle. Same fluid.
To Power steering pump problem
