C6 Vert Automatic Top Tech
Old Sep 13, 2025 | 09:01 PM
2THEXTRM's Avatar
2THEXTRM
Cruising
Default C6 Vert Automatic Top Tech
My 2005 automatic convertible top surprisingly stopped working. When I turn the handle and pop the top, windows go down then I get a dash error that roof is not secure.. yeah I know. Local Chevy dealer said it's a sensor which I'm sure it is, not which one.
Is there anyone around Syracuse, NY that is knowledgeable to assist me to fix or at least help with how to convert to manual? I would be perfectly fine with manual.
Thanks!
Old Sep 14, 2025 | 05:01 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Lift up the carpet behind the passengers seat. You'll see the pump that operates the top. Use the tool in your glove box that turns the pressure screw. Turn it about one turn counterclockwise and it relives the hydraulic pressue and will allow you to operate the top manually.
This info is in your owners manual.
  1. Locate the pressure release bolt on the front side of the hydraulic pump.
  2. Use the wrench,located in the glovebox,and turn the pressure release bolt counterclockwise one revolution, to relieve pressure to the hydraulic pump. This will allow you to manually raise the convertible top.
  3. Then follow the steps under raising the manual convertible top. See “Convertible Top (Manual)” under Convertible Top (Manual) on page 2-60 or Convertible Top (Power) on page 2-67.
Tom
Old Sep 14, 2025 | 05:19 PM
2THEXTRM's Avatar
2THEXTRM
Cruising
Thanks for the reply, I should have noted I did have to relieve the hydraulic pressure to put my top back down.
I have popped the tonneau manually and even with the pressure relieved the top doesn't move very far and I am unable to open it manually without feeling like I have to force it too much and cause damage to fold it into the storage area to close the tonneau
I have searched through many threads here and don't find anything that matches what I have going on
Old Sep 19, 2025 | 10:00 PM
2THEXTRM's Avatar
2THEXTRM
Cruising
Btt
Old Nov 17, 2025 | 08:48 PM
2THEXTRM's Avatar
2THEXTRM
Cruising
Btt
Old Nov 18, 2025 | 11:17 AM
NORTY's Avatar
NORTY
OP~ Have you ever changed the hyd. fluid in the reservoir?
Also, is it close to the full line?
Lastly, does the fluid look like coffee/tea? It should look like water (but it's NOT water.)
You might have to locate a convertible top specialist in your area, as the C6 power top system is crazy complex.
To C6 Vert Automatic Top Tech
