Common problem in some climates ... the airbag gets sticky. I never found a good long-term solution. Except for covering the airbag with leather. Looks much better as well ...
I've had a lot of soft plastic things get sticky. Like umbrella handles, water bottles, etc. So far nothing has worked. I've not tried the ammonia, will have to remember that.
I tried the rubbing alcohol and dawn soap but that didn't work. The ammonia took off the sticky substance right off. I then wiped it down with water. Then finished it with some Aerospace 303
