TPMS Frequency
Old Oct 19, 2025 | 03:19 PM
The Kraken's Avatar
The Kraken
Default TPMS Frequency
Getting new tires on the car. They have a date code of 2514, so definitely getting some new meats. (just bought the car yesterday).
Anybody know the frequency on the TPMS for a 2011 GS. May as well get new ones of these to. I'm sure they are 14 years old at least.
Thanks everybody.
Old Oct 19, 2025 | 05:04 PM
Dano523's Avatar
Dano523
https://www.tpms.com/Schrader-33700-...8-corvette.htm
315mhz for USA cars, and some export cars like UAE, While most export C6 where 416Mhz for them instead.
Quick way to see what the car is set up for (and that your using the 2008-2012 TPMS, not the ones for 2005 to 2007), is look up the fob number on the back if it, to see if its 315 or 416 fob, since the tpms for your year, will match it in frequency as well.
So yes, for C6 4 different fobs and TPMS's, so you have the year cut off, then you have the 315 verses 416 for export cars.
And go with the Schrader tpms, since God only knows how long the oems have been sitting on the shelves/how aged out the batteries will be in the oems.
Old Oct 19, 2025 | 08:22 PM
Rebob0510's Avatar
Rebob0510
I bought OEM ones for my 2011 GS and they worked perfectly. I used the $10 TMPS programmer to program them. Its best to program the new sensors before they are mounted in the wheel because if they for some reason do not work you have to have the tires dismounted again. I got the sensors nuts and programming tool from amazon
GM Genuine Parts 20925924 Tire Pressure Monitoring System (TPMS) Sensor
https://www.amazon.com/dp/B004JBI93Q?ref_=ppx_hzsearch_conn_dt_b_f ed_asin_title_3
GM Genuine Parts 15234846 Tire Pressure Monitoring System (TPMS) Sensor Nut
https://www.amazon.com/dp/B004JBCENW?ref_=ppx_hzsearch_conn_dt_b_f ed_asin_title_3
VXDAS TPMS Relearn Tool for GM Tire Sensor TPMS Reset Tool Tire Pressure Monitor system Activation Tool OEC-T5 for GM Buick/Chevy/Cadillac Series Vehicles 2023 Edition
https://www.amazon.com/dp/B072BK693N?ref_=ppx_hzsearch_conn_dt_b_f ed_asin_title_4
Old Oct 19, 2025 | 08:43 PM
The Kraken's Avatar
The Kraken
Yikes, that's a lot of info. I'll get my pencil out and start copying. Thanks for the great info. Gotta love Amazon.
Old Oct 21, 2025 | 11:22 AM
dr_gallup's Avatar
dr_gallup
I bought SCHRADER 29212 from RockAuto for my '13 GS.
To TPMS Frequency
