Hud
1) Pull dash surround bezel by prying on both bottom corners (below right start button and left a/c vent) with a scratch-free tool. Once those areas pop out, you can work your fingers around, popping off the bezel. TIP: may have to lift top of dash slightly to remove and re-install this piece AND the instument cluster. Remove the dimmer, DIC, start and sensor plugs during removal. Remove the left pod dummy piece and install the new HUD switch.
2) With a 7mm nutdriver, remove the 4 cluster screws and the 1 left a/c vent retaining screw. Pull the cluster out, disconnecting the gray and black plugs.
3) Using a hacksaw that is an open blade on one end with a handle on the other, carefully cut the large duct on the right side. TIP: Don't just cut it wide enough to get the projector in - you need some room to get your hand in to tighten the right nut. You will want to cut it fairly close to the sensor that is screwed into the duct.
4) Once the duct is cut completely through, pull on it to yank it out which will break off the mounting tab on the left side. You can now remove the filler bezel on top of the dash and replace it with the HUD bezel. TIP: This is done by pushing the panel forward (toward the windshield) and pulling it up and out of the slots.
