Wheel identification
Old Nov 11, 2025 | 05:21 PM
canadamaniac's Avatar
canadamaniac
Default Wheel identification
Hi,
My rear passenger wheel is leaking air quite a bit. I took it off an it seems to have cracked at some point and been repaired so I'm thinking of replacing it. Does anyone know what model they are so I can start looking? They're on a 2008 M6 with the 3LT trim and Z51 package. I've not been able to find one that looks the same.
Old Nov 11, 2025 | 05:53 PM
visionary's Avatar
visionary
You might find one on Ebay. I have actually had good luck with used parts there. Good luck!
Mike F
Old Nov 11, 2025 | 06:27 PM
NORTY's Avatar
NORTY
Have you ruled out anything to do with the valve stem?
Old Nov 11, 2025 | 07:03 PM
canadamaniac
I pulled the tire off and used the soapy water spray trick. It's definitely leaking at the bead right where there's crack that was fixed. Coincidence? I doubt it.
I did find some similar wheels but they're either gunmetal or silver. Mine looks more chrome or polished to me.
https://www.originalwheels.com/chevr...te2008rims.php
Wheel Part Number: 5343 REAR (silver) or 5345 REAR (gunmetal).
Is the wheel part number stamped on the rim somewhere?
I may take it to a shop and see if it's fixable. It didn't start leaking until recently and has been slowly getting worse.
Old Nov 11, 2025 | 08:43 PM
jbc1995fb's Avatar
jbc1995fb
Here is the wheel page from the 2008 Corvette catalog.
I would contact Bob @HOUSEOFWHEELS Maybe he can locate a wheel for you.
CorvetteForum - Chevrolet Corvette Forum Discussion - View Profile: HOUSEOFWHEELS
Old Nov 12, 2025 | 07:18 AM
HOUSEOFWHEELS's Avatar
HOUSEOFWHEELS
Supporting Vendor
St. Jude Donor '03 & '11
That’s the 2008-2009 base and z51 5 double spoke
Bob
House of Wheels
561-445-7606
To Wheel identification
