Heat Exchanger
Old Nov 21, 2025 | 03:15 PM
Kingdog44's Avatar
Kingdog44
Default Heat Exchanger
On my 2012 GS M6 that heat small exchanger in front of the AC condenser is it a rear end cooler or a transmission cooler
Old Nov 21, 2025 | 06:36 PM
FatsWaller's Avatar
FatsWaller
If it’s on the driver’s side it’s the engine oil cooler.
Old Nov 22, 2025 | 08:56 AM
dr_gallup's Avatar
dr_gallup
Yes, engine oil.
Old Nov 22, 2025 | 12:26 PM
FatsWaller's Avatar
FatsWaller
Just FYI, the extra cooling that you have in your GS manual coupe includes
  • A heat exchanger for the manual trans, same as the auto trans would use, in the passenger side radiator end tank.
  • Differential heat exchanger - mounted on rear diff. The diff is equipped with a pump to flow diff fluid through the cooler. Air cooled.
  • Engine Oil cooler - air cooled mounted in front of AC condenser, driver side.
There's also a small power steering fluid cooler sitting behind the rad I believe, but I think all models would have this.
Old Nov 22, 2025 | 01:54 PM
Kingdog44's Avatar
Kingdog44
Ok FatsWaller thanks for the info, I tried to follow the lines to see where they went but with all the duct work they just disappeared
Probably is an engine oil cooler but its positioned center of the AC condenser
Old Nov 22, 2025 | 04:13 PM
FatsWaller's Avatar
FatsWaller
The EOC is mounted behind a baffle which covers a large part of the AC condenser. Not a great pic but you can see the 2 solid aluminum lines of about 1/2” od entering the baffle to hook up with EOC.
To Heat Exchanger
