Fuel lines...
1. Line within the driver and passenger tank that goes between the pump and the crossover
2. The crossover line
3. The line from the driver side pump to the frame rail line
4. the line at the engine to the fuel rail.
Does anyone make an aftermarket set??
I figure the vac/pressure lines at the top of the tanks can be easily replaced with a rubber fuel line and some hose clamps so no big deal on those...
RH Tank - Pipe, Fuel Feed and Return Pipe, Pump to Crossover PN 19431776 (2004-2013) - Discontinued, used examples on eBay for $300.00
The hard plastic fuel feed lines inside the crossover tube and in each tank are for pressurized fuel delivery to the engine.
When running, the right tank is emptied first, sending fuel through the hard feed line via a venturi siphon pump over to the left tank's electric pump and on to the fuel rail.
I did a LOT of googling after posting this and I have a plan...the two lines in each tank can be replaced with quick connect GM fittings + AN fittings as needed. The fittings run between the pump (quick disconnect) and the crossover (AN). The lines within the tank and crossover tubing will likely have to be a bit longer than normal (need to take care not to trigger float/bind floats) so you have the space necessary to remove. The jet pump has two quick disconnects, the main has one. The main has a line coming over from the jet pump that flows into the pump housing, no connection.
Thinking:
larger line - quick disconnect x2 , 2 pairs of AN fittings
smaller line - quick disconnect x1, 2 pairs of AN fittings.
crossover line in both sizes, use the other side of AN fittings from above.
2x Quick disconnect from the pump to the frame rail line
2x quick disconnect from frame to fuel rail.
This is now my new plan - anyone else who gets this done before me, please post in this thread the results/pics of what was done. I may test it out on the J line from the fuel pump to the frame line because i did not buy that one previously and mine looks a little crusty. Its easy to access without dropping the tanks though so i might hold off until i see leaks.
Oh, also all the vent lines i plan to just run rubber fuel hose + clamps if they fail. they should see barely any pressure and connect L,R, and charcoal canister above the tanks.
This all assumes the jet pump remains available - I may pick a spare up just in case. I am fairly certain the supply pump wont be an issue as there are lots of aftermarket pumps.
Hose, Crossover Pipe w/ Fuel Feed and Return Pipe (Inside Crossover) (2003-2013) PN 19436041 - $287.34 @ Van GM Parts Center
Hose - PN 25948212 (2004-2013) - Discontinued, used examples on eBay for $350.00
Hose Assembly, Fuel Feed Front (2005-2013) PN 10324452 - $71.44 @ GM Parts Giant
For the other poster: They retain that external crossover tube but replace the nylon inners. I would like to see a replacement for the external tube too.
edit. thinking some more... this is only true if the leak is small, i guess. If the crossover line to the jet pump bleeds enough pressure from the main, it might not be able to pressurize the fuel rail. i dont have a pump curve handy for the main pump so idk.
nvm, this was answered in an earlier comment.
Thinking:
Do not use lines below. they are "marginal" for fuel... will post the correct lines once i figure the right ones out.
EAR-306006ERL - -6 AN hose; 6 ft
EAR-751166ERL - female quick connect, locking nut (engine bay side) x2
EAR-800106ERL - hose to -6 AN (2 for engine side, 1 for fuel tank side) x3
EAR-804606ERL or EAR-806106ERL - 60 or 45 degree hose to -6 AN; will figure out which one needs on the fuel pump side. eyeball says 60, ordered 45 for Justin Case
EAR-991966ERL - female quick connect, clamp style (fuel tank side) x1
thought of going -8AN but if i start making enough power to need it, ill redo the fuel system since the rest of the lines aren't huge anyway.
https://m2performancegroup.com/produ...wVZDvW23SAzcsS
I installed this kit and the only issue to watch out for is your level float getting hung up.
This thread talks about that:
https://www.corvetteforum.com/forums...post1608197951
ANYWAY quick update. My dumb *** ordered auto-flex lines from EARLS when I should've been ordering a different line type for fuel supply. DANGIT. Going to be ordering the right one and will post that after.
also, dont be a dumbass and forget to fish over the fuel pump wire on the driver side, leading to having to drop the tank a second time.
