Won't shift????
Old Dec 30, 2025 | 04:55 PM
The Doctor's Avatar
The Doctor
Default Won't shift????
I'm sure this has been discussed but I couldn't find a thread that did so here goes??? I have a 2008 automatic and some times the shifter will not move at all. I'm well aware of the actuator squeeze in the front of the shifter being required to be depressed in order to shift (along with the brake pedal being depressed) but there are times it simply will not depress and shift? I've shut the car off and tried again and it always comes around and works in time but it's quite annoying to need to go and not be able to. Yesterday, my wife hit the brake pedal a couple times and she heard something in the console click then it worked just fine. Is this typical and is there a fix for this? Thanks in advance for any help.
Old Dec 30, 2025 | 05:25 PM
FatsWaller's Avatar
FatsWaller
If you’re talking about not being able to shift out of Park, there are numerous threads on this. It’s a problem with the micro switch that’s supposed to sense when you shift into park so that when you next go to shift out of park, the interlock solenoid will release when you step on the brake and allow you do do that. Its usually a problem with the micro switch and not the solenoid.
Old Dec 31, 2025 | 08:11 AM
hcbph's Avatar
hcbph
If it's as noted, yes it's likely the microswitches in the shifter, I know because it happened to me. C&S Corvettes have a replacement assembly along with a video on how to replace it. They use some stronger microswitches than oem. If you want oem, it's around $150 IIRC from C&S vs. around $650+ from Chevy. Some have replaced the switches, which is viable but you need to open the console up to find what you need and there are those that 'cut' the cams in the console to basically disable the shifter lockup.
If you want to try something I found out too late to test myself: try putting the car in accessory mode and see if it comes out of park easily. Theoretically you could do that to get to neutral then start it, kind of a delaying method if you're on the fence on what to do.
Good luck.
Old Dec 31, 2025 | 08:15 AM
DR-08C6Z51's Avatar
DR-08C6Z51
https://www.corvetteforum.com/forums...use-found.html
Here's an explanation of why it happens and possible solutions.
Old Dec 31, 2025 | 09:42 AM
surburban99's Avatar
surburban99
I have a 2008 with the auto transmission and this has started happening to me. Can the micro switch(s) be replaced or does it require replacing the entire shifter assembly? I'm not able to do the repair myself, so any idea what the dealer will charge to do this repair?
Happy New Year!
Old Dec 31, 2025 | 11:17 AM
FatsWaller's Avatar
FatsWaller
Happy New Year!
Generally speaking, dealers don’t repair, they replace. You could ask a dealership if they would - asking costs you nothing. And yes, you can replace the micro switch. There’s a few threads around that point to a replacement and they’re pretty cheap. If it was me, I’d spend the extra $$ and get this harness replacement https://www.corvettepartscenter.com/...-free-shipping. It’s plug and play - no soldering required. With that harness I’d probably do the job myself. Again, there’s a number of threads that explain how to get at the shifter and also YouTube videos if you search for them.
And Happy New Year as well.
Old Dec 31, 2025 | 11:25 AM
1Hotrodz's Avatar
1Hotrodz
You can buy the same or better micro-switches online for about $6.50 or less. Not a hard job to replace. But soldering is required. As a fail-safe, many owners attach a drawstring to manually release the parking pawl and run it into the center console. This works when the switch fails to make contact. This is not an alignment or travel issue with the switch. The problem is the contacts on the switch build up carbon and no longer make contact. Why they get carbon build-up is because when the switch is opened the collapsing field (reverse EMF) of the solenoid jumps across the switch contacts. The arcing is what causes the carbon build-up on the contacts.
Someone here, can't remember who but he is an EE, suggests placing a diode across the solenoid to prevent this from happening. Even though the switch is replaced the arcing problem will still exist. So it's just a matter of time before the problem comes back. Hence the drawstring addition. Some people even do away with this safety feature (locking park mechanism) completely, but I do not recommend bypassing a safety feature.
I wonder how GM corrected this problem in later years or if it was even addressed...
Old Jan 1, 2026 | 09:37 AM
surburban99
If I'm correct, what needs to be replaced is the automatic shifter harness located in the center console? I always like to know or "pretend" I know what I'm talking about when I go to the dealer for service
Old Jan 1, 2026 | 10:17 AM
FatsWaller's Avatar
FatsWaller
Essentially, you are correct. But, that harness is an aftermarket assembly, and not a part that you could purchase at the dealer. They won’t be able to find it on their parts diagram. What they would want is to do what they know how to do, and charge a diagnostic fee to determine what the problem is, and then replace the entire shifter assembly, assuming that they could still get a new one. I suppose you could just tell them to replace the shifter and skip the diagnostic. If you show up with the harness in hand and ask them to replace just the harness, I can’t predict what they will say to that because they likely won’t have any experience in doing that and won’t know how much labor will be involved. If they will do work based on time and materials, then maybe they would work on it. It varies by dealer. I’ve got 30 years of history of buying cars and service with a local Chevy dealer and their work is very good, but from experience they wouldn’t touch a job like that. There’s a dealer about an hour’s drive from me who sponsors our club, and they have done custom work for me. If you’re determined to take it to a dealer then all you can do is ask.
Old Jan 1, 2026 | 09:59 PM
surburban99
Thank you so much for the helpful information. I didn't know that the harness was an aftermarket fix. Will give my dealer a call and see what can be done.
Old Apr 14, 2026 | 06:14 PM
surburban99
Wanted to provide an update. My local Chevrolet dealer has been ordering and installing the harnesses from C & S Corvettes. The service writer said this has become an issue for the auto tranny C6's, and they have done a number of installs. The dealer fixed mine today, so far so good.
Old May 15, 2026 | 05:16 PM
The Doctor's Avatar
The Doctor
C&S Corvettes has the perfect replacement harness with new micro switches to fix this issue and they even made a step-by-step video to install this. Tomorrow, I'll get on this and hopefully never be stuck in park again. Thanks Lyle and Doc of C&S Corvettes. Here's the how to video:
Old May 16, 2026 | 05:54 AM
Whatscooking's Avatar
Whatscooking
The group of guys I run with,3, ordered up three of these harnesses from C&S and two of them failed immediately. Old Lyle said to me they weren't having any problems with them, right. Buy a roller micro switch and replace yourself.
Old May 16, 2026 | 09:52 AM
allhans's Avatar
allhans
I had this problem and the dealer took it in. First replacement part failed immediately (while they still had the car) and the second one worked.
Old May 16, 2026 | 12:50 PM
Corvette_Dez's Avatar
Corvette_Dez
Failed how? Switches were bad? One of the switches not activating? Did they test and adjust the switches?
Old May 16, 2026 | 04:38 PM
The Doctor's Avatar
The Doctor
My new harness is now installed. The video makes it look much easier than it was but it is now done and the car shifts perfectly well. We're headed out for a nice drive and I'll report in if the harness fails at all. By the way, the new harness clearly stated that all parts were fully tested before shipping?? Maybe they did have some bad components before.
Old May 16, 2026 | 07:25 PM
Whatscooking
yes the top right switch failed. I believe they were overheating the switch when the soldered the switch
To Won't shift????
