Wheels question
Old Jan 8, 2026 | 12:47 AM
Yguy's Avatar
Yguy
Default Wheels question
I’ve just gotten my C6 after 30 years of C4’s.
in my searching for a newer Vette I saw C5’s with 18x10’s front and rear.
so now I’m wondering, will the 19x10s on the rear of a C6 work if I have them on the front as well? If you’re able, show some photos as well, please.
thanks in advance for any help!
Old Jan 8, 2026 | 07:39 AM
jbc1995fb's Avatar
jbc1995fb
Why?
I've never understood this mentality.
You'd have to purchase 2 wheels, and I still don't think they would be able to rotate the 4 wheels/tires, this isn't a SUV or sedan.
I think some people that have huge horsepower change the rear wheel size to get beefier side wall tires for racing.
Old Jan 8, 2026 | 12:11 PM
Yguy's Avatar
Yguy
Originally Posted by jbc1995fb
Why?
Thanks for the reply.
from your comment, I’m not sure you understand what I’m asking.
my intent is to have 19x10s on all four wheels with the same size tires on them.
why do I want to do this? I guess the bottom line is that it’s my current rims are corrod-o-chrome, it needs tires, and most importantly, I’m wondering how they’ll fit in front, how they’ll look, and it’s ultimately my choice on my car.🍺🍺
Again, I genuinely appreciate your input.
Old Jan 8, 2026 | 12:19 PM
jbc1995fb's Avatar
jbc1995fb
Your car, your choice, do what ever you want. So you need 4 new tires and 2 new 19" wheels for the front to complete the look you're going for, correct?
There's computers on board and I think they're programed to recognize the 1" difference in the front and rear. I might be mistaken, but if you try to use the same size wheels and tires front and back, you'd have to adjust the tire side wall to keep that same 1". Again, I might not be explaining it the best.
I'm sure someone else will chime in.
Best of luck,
Jason
Old Jan 8, 2026 | 12:20 PM
NBVette_Canada's Avatar
NBVette_Canada
Sure, they'll work and look fine.....
Lifted Chevy Corvette Trail Boss Is the Huracan Sterrato's ...
Old Jan 8, 2026 | 12:25 PM
Yguy's Avatar
Yguy
Best of luck,
Jason
Actually, I think you did a pretty good job of explaining it. I had not thought about the difference in tire size diameter wise from front to back.. Thank you for reminding me so I guess my quest then would be to put the correct diameter tires on the front and rear. but it’s a look that I’m wondering how it would look before I make the move. Thanks again for your input. But does anybody have photos of a car that this has been done on?
Old Jan 8, 2026 | 12:29 PM
Yguy's Avatar
Yguy
Lifted Chevy Corvette Trail Boss Is the Huracan Sterratos ...
Old Jan 8, 2026 | 12:32 PM
jbc1995fb's Avatar
jbc1995fb
I'd drive that.
Yguy, what style wheels do you current have? got any photos of your car?
I guess my point is if you're or were about to buy 4 new tires, and 2 wheels, why not spend a little more and get 4 new wheels and tires and completely change the look of the car. Again, you choices.
Best of luck,
Jason
Old Jan 8, 2026 | 01:25 PM
PMPerformance's Avatar
PMPerformance
Easy answer is throw your rears on the front and you will have your answer.
The offset will not be correct though, but you will see how they poke vs asking people on the forum.
Old Jan 9, 2026 | 09:36 AM
hcbph's Avatar
hcbph
If you have directional tires, it makes sense to be 4 square to be able to easily rotate tires. I would think it could mess with the ABS but that's just a assumption on my part.
Old Jan 9, 2026 | 05:50 PM
dr_gallup's Avatar
dr_gallup
I know some people build track cars with a square tire setup but that will very definitely mess with the stock stability and traction control system. It's going to think the rear wheels are spinning all the time. I'm not sure if you can just reprogram the stock system or if you have to rip it out and replace it with an aftermarket system.
I used to change the wheels and tires on my 350Z twice a year between summer and winter. Once I was a little preoccupied and switched the fronts and rears. The traction control would barely let me pull out of the driveway. Lit up all kind of warnings and would not allow any throttle. I could not believe I had done it, had to pull them all off and swap them around immediately.
Old Jan 9, 2026 | 06:41 PM
JKNAPP's Avatar
JKNAPP
Best of luck,
Jason
Correct, you can run same diameter wheels font and back "square setup", alot of the road course guys do....you still need that 1" difference front to rear if you want (traction control, active handling, ect) or you can turn all the nannies off and drive it like it should be driven
Old Jan 9, 2026 | 07:20 PM
Yguy's Avatar
Yguy
Thanks for the replies so far. It’s given me some insight on how to approach this.
Old Jan 9, 2026 | 07:29 PM
Aardwolf's Avatar
Aardwolf
So much better handling without the tiny front tire width.
Go to willtheyfit.com or some other site to check fit specs.
Old Jan 10, 2026 | 10:14 AM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by JustinVette
The 19x10s can fit the front of a C6, but you’ll want to check offset and tire size first to avoid rubbing. OEM fronts are smaller, so spacers or a slightly different offset may be needed.
I agree.
Stock fronts are 25.6" tall and 10.8" wide.
Stock rears are 26.7" tall and 12.8" wide.
An option is 235/35/19 which are 25.5" tall and 9.3" wide, or 285/30/19 which are 25.7" tall 11.2" wide.
Check this tire calculator...
https://premiertiresandwheels.ca/pag...eter-and-width
To Wheels question
