Auto headlight issue
Old Jan 11, 2026 | 11:29 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Default Auto headlight issue
Head lights are on Auto setting so when I start the car (2011 Grand Sport) the headlights turn on. No problem. But after driving outside in bright sunlight for a long time they will not turn off. If I manually turn them off I get the message Headlights Suggested. Shut the car off and when I restart it they're off.
Anyone have any thoughts?
Old Jan 12, 2026 | 05:23 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Ambient light sensor on the dash would be my guess. Had to replace mine a few years ago.
Old Jan 12, 2026 | 08:25 AM
C6ToGo's Avatar
C6ToGo
A failing column multi-function switch can also do some funky things.
Old Jan 12, 2026 | 09:51 AM
hcbph's Avatar
hcbph
I've seen the message before after switching from auto to off or manual when coming out of the garage. Hit the reset button on the dash: removes the message. Nothing else here.
Old Jan 12, 2026 | 01:08 PM
SLWRNU's Avatar
SLWRNU
That was my thought also.
Is it a big job to replace it?
DIY??
Old Jan 12, 2026 | 10:19 PM
lobstah24's Avatar
lobstah24
Start here. Mine did the EXACT same thing. I replaced it and voila...works great!
Old Jan 12, 2026 | 10:31 PM
ValenciaOrange's Avatar
ValenciaOrange
I had this problem for a couple of weeks. Did nothing, and it has not come back. Car is always in garage.
Old Jan 13, 2026 | 08:04 AM
C6ToGo's Avatar
C6ToGo
DIY??
Pop the dash defroster grill out with a pry tool, disconnect and twist out the sensor. BE careful popping out grill...sun takes its toll on them and can crack at the slats (as mine did)
To Auto headlight issue
