If you are like me and have always been confused or concerned about oil temps watch this-
A lot of factors at play with oil temps. The LS3/LS2 engine has factory CAST pistons while the LS9 has FORGED pistons. Big difference in strength and ability to tolerate higher temps. NA vs boosted plays a huge role with oil temps. A factory cast LS3 pistons in a boosted application is affected more than a forged piston in a boosted application. Keeping oil temps UNDER 220F in a boosted application with cast pistons is best practice. While a forged pistons can handle higher oil temps when boosted.
Keeping the oil temps cooler also helps cool the piston with oil splash. A cooler pistons is less prone to contribute to detonation.
If tracking a car, an oil cooler is mandatory. GM figured this out and added oil coolers in the C8 as standard and of course dry sumps rule over wet sumps when it comes to tracking.
Summer driving, not beating on the car, I would see oil temps at 230F +. After adding an oil cooler, I now see 205F oil temps, even after highway driving and some accelerated runs.
i don't worry about oil until it gets over 270 on track... pressures go down over 250 but keep the RPMs up and don't worry about it. The ls is a truck motor after all it's fine
i actually think (like the video said) it's critical to get your oil up over 212 degrees to burn off any excess water. My car is a "drive it to the track, run laps, have fun" and it has a thermostat from improved racing to make sure the oil cooler isn't over cooling the oil on the street so that its burning off that water and enabling the car to be at temp when I enter the race track.
Getting oil temps over 212F to burn off moisture was probably my biggest takeaway from the video as well. I've seen a lot of owners post questions about this over the years. Like my myself this is probably the first car many have owned with an oil temp gauge.
Reason: more info
The bearing temperatures are usually 50F degrees HOTTER than the actual recorded oil temps. So if your oil temps are 250, your bearings are around 300F. So if the DIC shows 200F on oil temps, the bearing temperatures are at 250F. You won't have any "moisture" burn off issues.
Elevation also plays a role. Water starts to boil earlier at higher elevations, around 200F at 5,000 feet elevation.
Once the oil hits 180F, the oil is fully warmed up and ready for high RPMs.The new C8s with the dry sump and oil coolers, rarely see above 200F unless driven in hot summer and aggressive track driving. Most see 160-180F oil temps when just driving around.
Naturally aspirated LS3 vs boosted requires different oil temp parameters. Those cast pistons and detonation is what you have to watch for. Oil splash is what cools them on LS3s. While the LS9 and later LTs have oil squirtters which squirt oil onto the bottom of the pistons to help cool and lubricate them. I would not go over 230F oil temps on a cast piston with boost unless you had water meth to help cool that piston. A forged piston would not be an issue with higher oil temps.
I don't track my GS 6M dry sump and with the stock oil cooler it would eventually get up to about 160 most of the time even on a long drive in the summer. A good hard blast in the mountains would get it higher but it seemed a poor setup to me for purely street driving. I know GM set it up more as a intro track car but they should have at least put a thermostat in the oil cooler plumbing. I know a lot of people block off the cooler in the winter but that always seemed a real shade tree mechanic fix. I replaced the radiator with a Dewitts with the oil cooler integrated into the tank. Now it runs 180 on the same long summer drive and I can get it over 200 in the mountains. You don't really need to get to the boiling point to drive water out, as mentioned, the oil is a lot hotter in various parts of the engine.
keep in mind the oil temp sender is in the bottom of the dry sump tank, which I presume to be somewhat cooler than the engine.
I was going to try and relocate my temp sender to the unused port on the IR oil temp thermostat, but then never bothered. Not long after this, I noticed a NASCAR dry sump with the temp sender at the bottom of the tank, and asked the crew chief about the 'why' for using that location; He said that at high rpm any temperature difference between that, and an other location is kinda mitigated anyway. Moreover, one can then split hairs anyway regarding where that other location should be...so they just use that existing port. Because "race car".
To go back however, it would be interesting to see how much temp difference there is at normal low rpm temps. I suspect an engine location for the sender would read somewhat higher
Oil temps vs bearing temps are load dependent, RPM dependent and clearance dependent. NASCAR engine at Daytona. The sump temp at 280°F and oil temp at main bearing exit was 360°F, an 80°F temp rise across the bearing. The LS3 street/highway driving will typically see 30-50F temp difference between DIC oil temp vs bearing temps. That will increase with tracking and higher engine loads.
So if your DIC is showing 200F oil temps while highway cruise, the bearing temps inside the engine are at 230-250F. Nothing concerning.
Oil cooler thermostats are best. Improved Racing oil cooler t-stat on my wet sump starts to open at 180F and is fully open by 200F. My oil temps are 205F at highway cruise. Without t-stat, it would probably be 160F oil temps
I find it interesting that the additives in oil don't really start working until the 220 to 240 degree range as mentioned about 2 mins into vid.
Can you state the cooling effect of meth injection on charge temp?
The number I have seen for E85 is 70 deg C = 158 deg F.
My new engine has forged pistons so this is a question of curiosity. Perhaps it will help someone else.
Per the Holley article and study, they claim a 50/50 mixture, "If adding a combination of water and methanol reduces the inlet air temperature by 25 to 40 °F"
While 100% methanol will give you the most HP, the 50/50 mix will give you the best cooling effect for IAT and a better steam cleaning of the intake. Plus, 100% meth is really flammable and it carries a flame that is not visible in daylight so if it ignites outside of the engine, you will not be able to see the flames in the daytime. Although, 100% meth is the best for max HP. The safer option is always 50/50
A catch can also is a good idea as oil vapors have an octane rating of around 48 octane. So without the catch can, your PCV system introduces oil vapors into the intake and this then goes into your combustion chamber and drops your octane level. For a daily driver, it's fine, but on an boosted engine with higher compression, it's a good idea TO run a catch can.
The oil temp on my stock LS3 with supercharger regularly gets close to 240 deg. F in traffic. No problems whatsoever.
240F is not an issue when cruising but if you were in a climate like Arizona or similar, it would probably need an oil cooler, especially if you started driving hard.
The weak links are those cast pistons and tight piston ring clearances. GM ran it tight on the LS3 as they were building for NA and not a supercharger. The LS9 has looser piston ring clearances and forged pistons.
The hot oil temps don't help the cast pistons and tight ring clearances. Heat = expansion. One can hurt the piston or ring land on a stock LS3 pistons if things get too hot
I am in a climate like Arizona during the summer 😁 No need for a cooler IMO and I don't take it to the track for extended runs either.
I see. I wish the LS3 had forged pistons like the LS9 but GM engineers said that since it was not supercharged like the LS9, it didn't need them. That is "weak link" in the LS3 when boosting. I was told keeping the piston cool will prolong the life of the engine. The hot oil temps and hot intake temps will shorten the life of the pistons when running boost. If guys hurt the LS3 pistons by being too aggressive on the boost/power, they will rebuild the LS3 with forged pistons.
I want to play it safe as I don't want to be rebuilding engines $$$. So I stay conservative on power/boost and keep the oil temps cool to protect the cast pistons.
I haven't clicked on the video, yet.
But, I can tell you that the additive package in engine oils are "working" for initial start-up. Regardless of temperature.
The "rule of thumb" for engine oils is...for every 10 degrees above 280F, the oil life is cut in half. Is doesn't matter if the base stock is natural OR synthetic. It's the additive package that gets "cooked" at higher temps. (Above 300F sustained, and ur oil is ready to be changed.)
This, coming from a Tribologist...
EDIT: Just reviewed the youtube link. The oil guy has it mostly correct. (I've heard worse from automotive class instructors.)
Is the 280F the overall oil temp in the pan/sump and not the actual engine bearing temps (which are usually 40-50 degrees hotter), right?
Water saturation pressure isn't a binary function that suddenly turns on at the boiling point. You'll get plenty of water out of the oil even below the boiling point.
