When I purchased my C6 used, I only got one key fob and one key. I purchased a couple of fobs online they are cheap 15 bucks. I know how to program them. The thing is I need the actual key. We tried to make a key based off the original key that I got with the car and found out that that was a copy and several locksmiths were not successful. They said because that key was already a copy it could not work. We also tried to make a key using the Saturn blank that was not successful so if I went to a General Motors dealership, I just wanted to purchase a key. Is that possible and how much would it cost? I don’t need the fob. I just need the key
Yes, you just need the VIN number and the dealer can cut you a key. In addition to the physical OEM type key you can get B106 blank at the locksmith cut to fit also.
Best option is go to a chevy dealer. with registration for proof of ownership and the vin. Tell them you need the key code.. They will charge you about 20 -30 bucks for this code. Once they give it to you go to a locksmith and tell them that
you need a key cut and you have the code. That is the easiest and probably cheapest option. Had to do this not long ago to my daughters car.
