New hatch struts closing concerns
Old Feb 26, 2026 | 11:26 AM
wwwFLA's Avatar
wwwFLA
Default New hatch struts closing concerns
The new struts open with a vengeance but closing takes force to lower and lock. This is for an ‘11 GS. I can’t remember if this was the way it was when I bought it 15 years ago. Anyone have fix or do I just wait for it to age into a faster close?
Old Feb 26, 2026 | 03:06 PM
DarkC-6's Avatar
DarkC-6
Are you sure the new struts aren't too strong? You should be able to drop the hatch from being opened a bit (say a foot or so gap) and gravity should take it closed, or close enough where the pulldown mechanism finishes closing it.
Old Feb 26, 2026 | 03:34 PM
FatsWaller's Avatar
FatsWaller
While you could drop the hatch from a foot above, I'd suggest you don't do that. There's a pull down that closes the latch if you lower it down so rests on the top of the latch, and then push down a bit. Otherwise, you risk breaking the latch mechanism.
Old Feb 26, 2026 | 04:11 PM
darkmercury's Avatar
darkmercury
Is it also possible that dropping or slamming the rear hatch can break the glass?
Old Feb 26, 2026 | 04:20 PM
craigyboy's Avatar
craigyboy
Wrong ones fitted
Old Feb 26, 2026 | 05:05 PM
wwwFLA's Avatar
wwwFLA
That’s what I’m used to doing.
Old Feb 26, 2026 | 05:07 PM
DarkC-6's Avatar
DarkC-6
It won't break it
Old Feb 26, 2026 | 05:08 PM
wwwFLA's Avatar
wwwFLA
This what I’m doing now, prefer the former as it was not coming down fast enough to break anything, that is until it got too weak and came down on my head. That’s when I replaced the struts!
Old Feb 26, 2026 | 05:39 PM
craigyboy's Avatar
craigyboy
STRONGARM 6522 (D6522 this is what I have fitted
Old Feb 27, 2026 | 06:12 AM
449er's Avatar
449er
CF Community Team
I use nothing but the OEM struts that came new with the car, aftermarket struts may or may not have the proper resistance to work properly
Old Feb 27, 2026 | 07:43 AM
craigyboy's Avatar
craigyboy
well, mine work properly and exact same as the OEM
Old Feb 27, 2026 | 08:55 AM
C6ToGo's Avatar
C6ToGo
Do you still have the old struts? One old and one new on the hatch can decrease the lifting pressure..
Old Feb 28, 2026 | 12:12 PM
wwwFLA's Avatar
wwwFLA
I tossed the old when I did replacement. I’ll try a little soap.
Old Feb 28, 2026 | 01:16 PM
craigyboy's Avatar
craigyboy
It won't break it
It will bend the hinges and you will find the hatch won't line up.
It's simple, the wrong pressure ones have been fitted.. It really is that simple
Old Feb 28, 2026 | 02:00 PM
449er's Avatar
449er
CF Community Team
Well, I said it before, use the oem struts & there will be no issues.
Old Feb 28, 2026 | 02:39 PM
DarkC-6's Avatar
DarkC-6
You must not have read the comment I was replying to because I wasn't even talking about the struts.
To New hatch struts closing concerns
