Easier harmonic balancer replacement
Old Apr 19, 2026 | 01:49 PM
Jonnygun's Avatar
Jonnygun
Default Easier harmonic balancer replacement
Good news!
I replaced my balancer without dropping the sub-frame or removing the steering rack. I wanted to share it with anyone who is dreading the job.
I found this video on YouTube, it is brief and lacks some details but it looked like a much easier alternative to the 2 common methods.
So I replaced mine yesterday, took me about 6 hours including 2 trips to the store to pick up some deep sockets I didn’t own.
Here is the process:
Turn wheels to the right and remove the boot and passenger side tie rod.
Remove fan assembly.
I removed the air intake parts to replace my belts.
Remove passenger side rack mounting bolt and loosen driver side bolt.
I laid a 2x4 across the engine bay and used a ratchet strap to hold the rack up just enough to get to the crank bolt. There is enough room to remove it and pull the crank pulley.
I installed the crank seal, new pulley and pinned the crank.
I’m pretty sure with access to a lift instead of jack stands this is doable in 3-4 hours.
Old Apr 19, 2026 | 08:31 PM
Rebob0510's Avatar
Rebob0510
Thanks for the link to the video. I dont have the wobble but did buy a ATI balancer just to have incase it does show up. After seeing this video I might have to tackle it next winter.
Old Apr 19, 2026 | 09:08 PM
RicardoFors68's Avatar
RicardoFors68
I was thinking of doing this, now I have the challenge to replicate this, thank you.
Old Apr 20, 2026 | 09:21 AM
Dreamer2's Avatar
Dreamer2
After reassembly, is an alignment needed?
Old Apr 20, 2026 | 09:56 AM
1Hotrodz's Avatar
1Hotrodz
No alignment needed. As shown in the video the, the tie-rod bolts directly to and bottoms out on the steering rack., just as it did before. The procedure shown could save hours of labor. I need to look into this further.
Old Apr 20, 2026 | 04:11 PM
RicardoFors68
It's almost too easy. But I'm down.
Old Apr 20, 2026 | 04:54 PM
Pettrix's Avatar
Pettrix
Interesting, I wonder why this hasn't been done before this way? I always thought it was just two options: drop sub-frame or remove steering rack
If one has an A&A supercharger setup, would this method still work?
Old Apr 21, 2026 | 06:12 PM
Jonnygun's Avatar
Jonnygun
I wrapped the shaft with Teflon tape to mark its position. No alignment necessary.
Old Apr 21, 2026 | 06:13 PM
Jonnygun's Avatar
Jonnygun
I don’t see why it wouldn’t work with the supercharger. You may have a little less room up top to ratchet strap the steering rack out of the way, but it should work..
Old Apr 21, 2026 | 07:45 PM
Jonnygun's Avatar
Jonnygun
Good question why nobody’s doing it this way other than the guy in the video I found. It really wasn’t a bad job.
Old Apr 21, 2026 | 09:58 PM
Pettrix's Avatar
Pettrix
Would the steering sensor need to be reclocked?
Is your car an automatic? Did you pin the ATI balancer? Any pics of the finished install?
Old Apr 22, 2026 | 06:50 PM
Jonnygun's Avatar
Jonnygun
No, you are merely rotating the passenger end of the steering rack up a few inches for access to the crank bolt. You don’t disconnect the link to the steering column.
Old Apr 24, 2026 | 01:58 PM
Pettrix's Avatar
Pettrix
Did you install an ATI Balancer? How hard was it to pin the balancer to the crank?
Old Apr 25, 2026 | 05:34 PM
Jonnygun's Avatar
Jonnygun
I did a power bond balancer.
Pinning the crank was about 15 minutes of drilling under the car, checking the depth several times.
Old Apr 26, 2026 | 04:29 AM
449er's Avatar
449er
CF Community Team
Any procedure that saves some labor time while doing this replacement is certainly worth looking at
Old Apr 27, 2026 | 12:59 PM
tjl5709's Avatar
tjl5709
Default Very Timely & Appreciated
Good news!
https://m.youtube.com/watch?v=Sq-e462nrEI
Thanks for posting. My 08 has the wobble.
Old May 17, 2026 | 03:16 PM
BET VETTE's Avatar
BET VETTE
Is that a shop or home garage
and who on here has actually done it that way
Old May 18, 2026 | 10:59 AM
csnow's Avatar
csnow
Nice, that is definitely a time saver for sure. Thank you for that.
To Easier harmonic balancer replacement
