Need Help!! Speedometer Flickering.
Old May 16, 2026 | 05:37 PM
axlets's Avatar
axlets
1st Gear
Default Need Help!! Speedometer Flickering.
I attached a video, my speedometer needle is flickering pretty bad. But it only flickers when my diff makes noise on acceleration. I know I need a new rear differential, but what is causing this to happen on the cluster. Could my diff be causing an interference with the sensor somehow?
File Type: mov
Old May 17, 2026 | 10:11 PM
Corvette_Dez's Avatar
Corvette_Dez
Absolutely it could be related. The vss is located on the diff case.
