C6 Performance...how will it stack up?
Old May 5, 2003 | 04:04 PM
needhlp's Avatar
needhlp
Default C6 Performance...how will it stack up?
Will it be the performance of a 2002+ z06? Or will it be about equal to the regular c5 right now? Any info would be appreciated.
Old May 5, 2003 | 04:35 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Default Re: C6 Performance...how will it stack up? (needhlp)
My guess is that it will be more than the current C5...
Old May 5, 2003 | 08:27 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Default Re: C6 Performance...how will it stack up? (Traceys2vettes)
Autoweek says the XLR turns 0-60 in 5.7 with a 320 horse Northstar. The C6 on the similar chassis is suposed to have between 405 and 425. Basic algebra says that would be in the 4.2 range.
C6 looks to have the same or a little more power than the ZO6 and a lower weight. I'm betting the C6 standard coupe runs with today's ZO6. Alot will depend on the torque numbers and final gearing. But I wouldn't be suprised to see a sub 4 0-60 and high 12's through the quarter.
Old May 7, 2003 | 04:32 PM
GoForBroke's Avatar
GoForBroke
Default Re: C6 Performance...how will it stack up? (BuckyThreadkiller)
except that the relationship between HP and acceleration is not linear. Pulling 0-60 times in the high threes would be quite a feat with 425 HP and 3200+ lbs.
-Jim
Autoweek says the XLR turns 0-60 in 5.7 with a 320 horse Northstar. The C6 on the similar chassis is suposed to have between 405 and 425. Basic algebra says that would be in the 4.2 range. C6 looks to have the same or a little more power than the ZO6 and a lower weight. I'm betting the C6 standard coupe runs with today's ZO6. Alot will depend on the torque numbers and final gearing. But I wouldn't be suprised to see a sub 4 0-60 and high 12's through the quarter.
Old May 7, 2003 | 04:51 PM
LongTimer's Avatar
LongTimer
Default Re: C6 Performance...how will it stack up? (GoForBroke)
Just got my new Car & Driver - about 6 pages on the XLR (they like it alot by the way), with the C6 mentioned several times in the article. C&D also got a 0-60 time of 5.7. They list the weight at about 3660. Rumors have the C6 hitting the floor at 3100 lbs. But, comparisons between these two at this point seem a bit useless. The engines are very different, the tires are much smaller on the XLR, the chassis are tuned very differntly, the XLR carries 400-500 lbs more weight. Just not much insight from my point of view.
To C6 Performance...how will it stack up?
