V-12 Caddy
Old Aug 19, 2003 | 12:08 PM
cypher745's Avatar
cypher745
Default V-12 Caddy
I have read that Cadillac has been given the green light to produce a V - 12 engine that will initially go into the Escalade (Only current Caddy with enough room under the hood.), but then go into other Cadillac's as they become available.
Now I don't think that this engine will find it's way into a Corvette anytime soon. But the engine is rated at 500 hp. And seeing as how the Corvette ALWAYS has the highest RATED hp engine, is it safe to assume that the next Z06 will be just a bit north of that? :party: :cheers: :flag :party: :hurray:
Old Aug 19, 2003 | 12:17 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: V-12 Caddy (cypher745)
No it doesn't.
Old Aug 19, 2003 | 12:49 PM
AF_Cadet's Avatar
AF_Cadet
Default Re: V-12 Caddy (Scissors)
1987 Buick GNX had more power than the vettes that year.
I wonder if they will build the cadillac Sixteen V-16 with 1000 hp and 1000 FTlbs of tourque
Old Aug 19, 2003 | 01:02 PM
Butta's Avatar
Butta
Default Re: V-12 Caddy (AF_Cadet)
The engine had more horse power, but it wasn't rated by gm as higher.
Old Aug 19, 2003 | 01:09 PM
cypher745's Avatar
cypher745
My point exactly. Other GM cars in recent memory may have actually had more power than the vette, but they were never rated as such. So if this caddy is being rated at 500 hp (It could have 600 hp for all we know) Does that not mean that the Z06 will be rated at least a couple of ponies higher?
Old Aug 19, 2003 | 02:19 PM
Rocketblock's Avatar
Rocketblock
I have no comment on this one! :yesnod:
Old Aug 19, 2003 | 02:39 PM
logansowner's Avatar
logansowner
No it doesn't.
Thats why he emphasized on RATED :cheers:
Old Aug 19, 2003 | 03:20 PM
GDP's Avatar
GDP
I think we heard 510 for the Z06 version. :eek:
Old Aug 19, 2003 | 03:26 PM
Scissors's Avatar
Scissors
Default Re: V-12 Caddy (logansowner)
No it doesn't.
Which is why I said "no it doesn't."
Old Aug 19, 2003 | 03:33 PM
cypher745's Avatar
cypher745
Scissors, could you give an example illustrating where this has not been the case? Thanks.
Old Aug 19, 2003 | 04:56 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Normally the rule at GM is no cars rated higher in HP than the Corvette.
The GNX was one exception to that rule. Its possible there are a few others but in general that rule is still in effect.
The 87 Corvette was rated at 240 hp and the GNX was rated at 276. It was obviously pumping out a good deal more than that with 0-60 times of 4.7 and 1/4 mile times of 13.4 @104. All of that with a curb weight of 3545 lbs.
I suspect the reason to be the limited number produced in 87. Only 547.
Old Aug 19, 2003 | 05:25 PM
SWCDuke's Avatar
SWCDuke
Default Re: V-12 Caddy (2k2C5)
V-12s in cars are primarily a "gee-whiz" feature - not really a good solution for a lightweight sports car. As long as you can package the required displacement within a bore and stroke of about 4.5 x 4.0, a V-8 will be lighter and take up less space. This places the practical limit of a high performance V-8 at around 500 CID.
As you go beyond a 4.5" bore compression is limited due to detonation issues, though WWII aircraft engines typically had 5.5" bores, and beyond 4.0" in stroke high piston speeds place an increasing limit on rev potential due to mechanical stress and volumetric efficiency limitations.
Consider that the current LS-series weighs a little over 500 pounds dressed and occupies and cubic envelope about two feet on each side, and the new Gen IV engines will be about the same weight and volume with improved output.
One of the reasons why the Maranello is so heavy is its heavy V-12 engine, but they sure sound great!
Duke
Old Aug 19, 2003 | 07:11 PM
Scissors's Avatar
Scissors
1987
Buick Grand National GNX: 275 BHP and 360 lb-ft.
Chevrolet Corvette: 240 BHP and 345 lb-ft.
Old Aug 19, 2003 | 11:19 PM
ghostRder's Avatar
ghostRder
No it doesn't.
Actually I don't think GM gives a hoot about Vett owners, the bottom line is the bucks. I just posted something I read in an article about the new Caddy CTS V with the Z06 ( LS6) engine and goes 0-60 in 4.6 seconds --just as fast as a C5 !
[Modified by ghostRder, 10:20 PM 8/19/2003]
Old Aug 20, 2003 | 07:59 AM
Scissors's Avatar
Scissors
Default Re: V-12 Caddy (ghostRder)
Just as fast as a stock A4 C5 Coupe of 'Vert, yes; and this is a good thing. The C5 didn't suddenly get slower just because GM finally has the ***** to build a powerful, luxurious sport sedan. It makes no sense and hurts C5 owners in no way for GM to kick the crap out of the competition.
Old Aug 20, 2003 | 10:33 AM
FAST LS1's Avatar
FAST LS1
The idea use to be true at GM that no car could have an engine output rated higher than the Corvette, but now that Lutz is there I think things might have changed. Lutz knows that the luxury scene has heated up to a full scale war in the hp department. Look at the new Benz's and BMW's coming out. You can now get a twin turbo V-12 Benz with 575+hp, and an AMG version is yet to come with over 700ftlbs of trq. The next BMW M5 will have a 500hp V-10. I wouldn't be surprised if Lutz broke the rule of rating a luxury car/truck with a higher output than the Vette since they aren't in competition with eachother.
Old Sep 9, 2003 | 11:22 AM
sacsrpc's Avatar
sacsrpc
Default Re: V-12 Caddy (Formula)
I agree the new HP wars may change GM's attitude about rating cars higher than the vette. There will be one difference though when compared to the 87GN (&91 syclones/92 93 typhoons).... the vette will not be outdone in the HP category by a vehicle with a lower base price.
Never out do your flagship with something that costs less. :nono:
[Modified by sacsrpc, 11:22 AM 9/9/2003]
To V-12 Caddy
Old Sep 9, 2003 | 11:43 AM
FAST LS1's Avatar
FAST LS1
Default Re: V-12 Caddy (sacsrpc)
I think your right because all the high horsepower luxury cars/trucks will cost more than the Vette.
Old Sep 9, 2003 | 01:26 PM
LongTimer's Avatar
LongTimer
Default Re: V-12 Caddy (SWCDuke)
Duke
:iagree:
Old Sep 9, 2003 | 07:47 PM
GDP's Avatar
GDP
1987
