C 6 Engines:
Old Aug 20, 2003 | 11:12 AM
edlipman's Avatar
edlipman
Default C 6 Engines:
Here is some info I got from a GM engineer at the Woodward Cruise in Michigan.
The LS1 changes to LS2 with 6.0 liters or 366 cu and 400 hp.
The LS6 changes to LS7 with 6.4 liters or 390 cu and 500 hp.
The above is a accurate as the engineer would say. I hope this comes to pass!!!!!!!!!!!!!!!!!
Ed :smash:
Old Aug 20, 2003 | 11:44 AM
Daryl's Avatar
Daryl
Default Re: C 6 Engines: (edlipman)
Those numbers make perfect sense. The base C6 has to have a minimum of 400 ponies. :steering:
Old Aug 20, 2003 | 12:07 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Ed :smash:
That's also the same information that's been stated many times on this board over the past year.
Sorry man, but you're a bit late. :lol:
Old Aug 20, 2003 | 01:59 PM
Pipes's Avatar
Pipes
:thumbs:
Thanks for the reaffirmation!
:seeya
Old Aug 20, 2003 | 02:25 PM
SWCDuke's Avatar
SWCDuke
This information jibes with what can be concluded from the various rumors and other intelligence over the past one to two years. The fact that is was stated by a St. Catherines employee is further confirmation. The actual bore and stroke of the 6.4 should be 103 x 96 mm (GM Powertrain does all design in metric.), so depending on how they round, the 390 might actually be quoted as 391.
Duke
Old Aug 20, 2003 | 02:56 PM
Hurricane's Avatar
Hurricane
Moderator
Cruise-In I Veteran
Thanks for the information!
:steering:
Old Aug 20, 2003 | 02:59 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Default Re: C 6 Engines: (Hurricane)
:cool: :thumbs:
Old Aug 20, 2003 | 03:24 PM
GDP's Avatar
GDP
I just don't understand why they are doing so much to get 18 cubic inches. :confused:
But come to think of it, it might be because having the 6.0 as a base engine, it would be even easier to up the displacement for te HP version. Hmmmm.
Old Aug 20, 2003 | 05:39 PM
FAST LS1's Avatar
FAST LS1
Default Re: C 6 Engines: (GDP)
Your probably right, the 6.0 and the 6.4 might very well have the same bore, just that the 6.4 will have a longer stroke. They probably can't go much larger on the bore and still meet emissions and avoid detonation at a high compression ratio.
Old Aug 20, 2003 | 05:58 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Default Re: C 6 Engines: (Formula)
Same bore means you can machine it on the same line. If the rods are longer it doesn't impact production costs or interrupt the line for re-setting the machines.
Old Aug 21, 2003 | 12:31 AM
Jinx's Avatar
Jinx
Four hundred horsepower is not enough.
Old Aug 21, 2003 | 12:51 AM
Alphaq's Avatar
Alphaq
Ed :smash:
Why would they change a LS1 to LS2. Just keep the LS6, it already has 405 hp. :confused:
Old Aug 21, 2003 | 12:52 AM
AP's Avatar
AP
Cool
Old Aug 21, 2003 | 03:03 AM
backtrail69's Avatar
backtrail69
St. Jude Contributor
Default Re: C 6 Engines: (Scissors)
:cool: :cool:
Old Aug 21, 2003 | 07:28 AM
Scissors's Avatar
Scissors
Default Re: C 6 Engines: (Alphaq)
Because if the LS2 is superior in ways other than peak HP to the LS6, then it would be stupid to stay with the LS6.
Old Aug 23, 2003 | 10:29 PM
aficionado's Avatar
aficionado
Car and Driver said in the July issue,
" the current 5.7 liters will be stoked to 6.3 liters. the new engine should make up to 450 hoursepower and 450 pound-feet of torque.
Old Aug 23, 2003 | 10:35 PM
GDP's Avatar
GDP
Default Re: C 6 Engines: (aficionado)
Car and Driver is wrong.
To C 6 Engines:
Old Aug 24, 2003 | 04:04 AM
MonnieH's Avatar
MonnieH
Default Re: C 6 Engines: (Jinx)
Could you imagine hearing this back in 82, and 84! I remember when the 84 C4 came out 400hp was something that only happend back in the 60's and was a number we would "never" see again.
I have been considering doing the heads and cam on my car to get it to around 550hp or so in N/A trim. AND THIS SOUNDS REASONABLE TO ME FOR A STREET CAR!!! 20 years ago a drivable street car with that kind of power was about as likely as a Star Trek transporter would be.
These ARE the good ol' days right now!
Old Aug 24, 2003 | 02:27 PM
Joe's Eray's Avatar
Joe's Eray
Default Re: C 6 Engines: (MonnieH)
:iagree: :iagree:
[Modified by BrightRed C5 SWFL, 2:28 PM 8/24/2003]
Old Aug 24, 2003 | 06:57 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
:iagree: :cheers:
Not only that but that 400 HP in the 60's would probably only dyno at 350 using today's SAE net numbers :yesnod: I remeber in the mid 70's I was afraid I would not be able to buy a powerful car in the future years when I would have the means to pay for one.......boy, compared to 1976 performance levles, I had nothing to worry about. :lol:
