Base C6 Engine....
Old Dec 7, 2003 | 12:58 PM
PeteyPete's Avatar
PeteyPete
Default Base C6 Engine....
We've all been guessing and arguing over how much HP the new base vette is going to have...GM and insiders have been giving us interesting hints such as "Think Four and Five" and "Ted Williams batting average"...but I just saw Car&Driver TV and they previewed the SS concept which got me thinking.
The SS concept car has a Gen3 aluminum 6.0-liter V-8 engine pushing 430 horsepower and 430 lbs.-ft. of torque. Could this be the engine we're going to see? If they can produce an engine w/ the same displacement as the C6, and have the HP up around 430...why push it down to 405 as many claim?
Whaddya guys think?
Old Dec 7, 2003 | 01:25 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Base C6 Engine.... (PeteyPete)
The highest average ever by Ted Williams was .407 in 1953, hopefully the HP on C6 is at least that high :)
Old Dec 7, 2003 | 01:46 PM
Jinx's Avatar
Jinx
Because concept cars don't have to run for 100,000 miles.
Old Dec 7, 2003 | 01:58 PM
GDP's Avatar
GDP
Because 430 would be too much and too costly, with poor fuel efficiency. If Chevy is going to produce the SSR, it won't have more than the 'vette.
Old Dec 7, 2003 | 02:35 PM
1969stingray1969's Avatar
1969stingray1969
Default Re: Base C6 Engine.... (Drewdog)
But at least the first game of the year he had a 1000 :lol: :thumbs: batting average. :cheers:
Old Dec 7, 2003 | 02:42 PM
99quicksilver's Avatar
99quicksilver
St. Jude Donor '03-'04-'05
My guess is it will be around "405" Already done that in the Z06 so it's in the can already!
The new Z06 will be higher....maybe around 430
:auto:
Old Dec 7, 2003 | 03:31 PM
ghostRder's Avatar
ghostRder
Default Re: Base C6 Engine.... (GDP)
25 more Hp is too much and too costly with lousy gas mileage? Why ? Think positive GDP think positive
Old Dec 7, 2003 | 06:36 PM
SWCDuke's Avatar
SWCDuke
With modern engines, there is only a very weak link between engine size, peak power, and EPA fuel economy. Look at Z06 - more power and shorter gearing, yet it achieves the same EPA fuel economy numbers as C5 Coupe and Convert.
During the EPA emission certification test, which is where EPA fuel economy numbers are derived, all cars are driven according to the same speed-time schedule and shifted at the same speed unless the manufacturer has some type of shift assist function. In the case of C5 (and probably C6) the 1-4 skip shift helps achieve good EPA numbers, and this is the only reason it's there. During this certifcation process the throttle is barely cracked open and revs likely never exceed 2500.
EPA fuel mileage is driven primarily by weight and aero. That's why all C5s get 18/28, which is well above the guzzler threshold. Expect C6 to exceed these number by 1 MPG, and C6 Z06, even with a 6.4L 500 HP engine will be no worse than C5.
Duke
Old Dec 7, 2003 | 07:27 PM
Butta's Avatar
Butta
Whaddya guys think?
This is a :_dupe: We have beaten to death the SS Concept talk.
Old Dec 12, 2003 | 07:27 PM
Tom Steele's Avatar
Tom Steele
Default Re: Base C6 Engine.... (99quicksilver)
No way. If the Z06 has 430hp and the coupe/conv have 400-405 the Z06's will sit on the dealer's lots until they rot. If GM has much less than a 40-50hp difference in the two engines they are in for trouble with the Z06.
Old Dec 12, 2003 | 09:52 PM
mray's Avatar
mray
If GM can get 405hp out of the 5.7 with relatively minor adjustments, why would you think 430hp or even 450hp would be out of the questions for a 6.0?
Old Dec 12, 2003 | 09:57 PM
JerriVette's Avatar
JerriVette
Default Re: Base C6 Engine.... (mray)
How much power and torque the new automatic transmission can stand will give insight to how much hp the base C6 engine has..
Wasn't that always the limiting factor on the C5 coupe and convertible?
I don't think GM wanted to do the LT4/stick shift & LT1/automatic combos again...
I don't think they will for the c6 either so the pivotal factor on hp and torque will the the automatic transmissions capabilities..
Just a guess though on my part.
To Base C6 Engine....
