C6 passive entry/push button start
Leadership - Corvette is Chevy's flag ship and should have the best of the newest technology.
Safety - If you are fleeing an attacker (or angry spouse :lol: ) you don't have to fumble through your pockets or purse (especially a purse) for your keys. As long as you have the fob somewhere on you, you will be able to open the door and start the car. Additionally, you almost never have to worry about locking your keys in.
Appearance. No lock cylinder to detract from the lines of the car.
[Modified by Scissors, 10:56 AM 12/14/2003]
By moving toward what some view as gratuitous technology, GM runs the risk of shunting a portion of those consumers to other makes. It is possible that GM views that portion of purchasers as either shrinking or becoming irrelevant, for whatever reason. FWIW.
Shouldn't leave a running car unattended anyway. It's not safe and a thief will just bust out the window regardless.
By moving toward what some view as gratuitous technology, ......
I like it other then that though.
And then they'll have a good laugh about proximity systems. :D
So, the bright spot is that the inherent liabilities of this spurious technology are forcing GM to put OnStar on Corvettes after all these years? :)
I'm pretty sure that the car will not start unless the the fob is actually inside the car and most likely the moment you got out it would shut down the engine.
I'm pretty sure that the car will not start unless the the fob is actually inside the car .....
GM had an XLR at the NCM Labor Day celebration. The car would not start unless the key fob was inside the car. (My wife tried to start it.)
But I hope this doesn't happen because I really like the idea.
Seriously, though, the C6 and XLR only check for the fob when the door handle is operated or the push-button start is operated. If it continually checked for the fob, it would wear the fob's battery down just on a long cruise.
[Modified by Scissors, 7:00 PM 12/15/2003]
