6L80-E
Old Apr 7, 2004 | 04:05 AM
Runge_Kutta's Avatar
Runge_Kutta
Default 6L80-E
http://www.autoweek.com/cat_content...._code=06984398
"The droptop is powered by Buick’s experimental twin-turbocharged, intercooled global 3.6 liter
V-6 engine that generates 400 hp and 400 lb.-ft. of torque. It also is equipped with a Hydra-Matic
6L80-E six-speed, rear-wheel-drive automatic transmission equipped with manual tap-shift gear
selection."
Old Apr 7, 2004 | 04:15 AM
Guest
Guest
Posts: n/a
Default Re: 6L80-E (Runge_Kutta)
Old Apr 7, 2004 | 10:52 AM
Curtis A. Franz's Avatar
Curtis A. Franz
One has to question the "80" designation. The 4L65E in the C6 has been described as modified to 400 lb-ft specs. Heck yes I want the six speed but the torque rating seems too low. Also is this the dual shaft?
Old Apr 7, 2004 | 11:14 AM
Curtis A. Franz
This is the now old press release of Powertrain Technologies' 6 speed hydramatic. It reads like apple pie, Chevrolet and motherhood. After all the success in finding C6 details before the announcement date it is another thing that we are ignorant of. Is it actually headed for the C6 and if so when?
Hydra-Matic 6-Speed Automatic Transmissions
Delivering performance and fuel economy benefits
Overview:
GM Powertrain introduced its first 6-speed automatic in the 2001 Buick Bengal concept car.
Several 6-speed variants will be featured in GM vehicles worldwide.
The first 6-speed will debut in 2005 (applications to be announced at a later date)
New Technologies:
Clutch-to-clutch
Controls characterization
TEHCM – Transmission Electro/Hydraulic Controls Module
Shift-by-wire (ETRS)
Features:
Neutral idle
Automatic grade braking
Driver Shift Control (DSC)
Enhanced Performance Algorithm Shifting (PAS II)
Next-generation tow/haul mode
Benefits:
Fuel economy
Performance
Premium shift quality and driveability
[Modified by Curtis A. Franz, 8:15 AM 4/7/2004]
Old Apr 7, 2004 | 12:20 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
The question is, will it even fit in the C6?
Additionally, what is the 6l80-e rated for on input shaft speed?
[Modified by Scissors, 12:22 PM 4/7/2004]
Old Apr 7, 2004 | 03:32 PM
Runge_Kutta
Default Re: 6L80-E (Curtis A. Franz)
Curtis,
I don't ever recall anyone ever attaching a name to these
transmissions beyond X13R, X14R, X15R, and X16R. Motor
Trend said 6L60-E and Hib Halverson said 6L65-E. I suspect
that a 6L80-E will be in the C6 lineup for MY2006 - once
the transmission family finally enters production.
Old Apr 7, 2004 | 05:25 PM
Curtis A. Franz
I suspect
That certainly is my hope. I just got Car & Driver and the Buick article there says the engine is rated at 400 lb-ft. I think I read too much into that Autoweek bit...the tranny can be rated at much more than the engine and that would be good. GM just never seems to do that tho.
Old Apr 7, 2004 | 09:36 PM
I Bin Therbefor's Avatar
I Bin Therbefor
Not just rear wheel drive but rear mounted, as in transaxle. Remember that Vette used a truck trans that was designed to enable four wheel drive application as well as two wheel in order to get the proper transmission housing to be able to mount it in the rear.
Before it shows in the Vette, any new transmission will likely be designed for the same applications. Watch the truck or four wheel drive auto announcements for a "vette-able" transmission.
Old Apr 8, 2004 | 10:27 PM
Curtis A. Franz
Default Re: 6L80-E (I Bin Therbefor)
This is all I can find in the way of hydramatic news. It says calendar year 2006 and that is not good. http://www.gm.com/automotive/gmpower...ews/press2.htm
Old Apr 9, 2004 | 11:13 PM
Curtis A. Franz
Well in spite of that GM announcement here is a press release spun off that says 2005 calendar yearand the clutch to clutch (dual shaft) design. Gads, lets hope this one is correct...
New RWD 6-speed Hydra-Matic Transmission
Building on its strong heritage of transmission innovation, GM will introduce an all-new rear-wheel-drive family of Hydra-Matic 6-speed automatic transmissions beginning in the 2005 calendar year. The new 6-speeds, featuring multiple variants for GM cars and trucks, will provide performance improvements of about 4 percent to 7 percent and fuel economy improvements of about 1 percent to 4 percent.
Optimizing the flexibility and responsiveness of advanced microprocessor integration, the new 6-speed transmissions will feature a number of benefits such as an enhanced performance algorithm shift, clutch-to-clutch shifting, automatic grade braking and Driver Shift Control tap-up/tap-down operation.
Old Apr 10, 2004 | 04:26 AM
Gene K's Avatar
Gene K
I guess this explains why we are still using he 4spd auto. Also it appears to me GM made the MN6 std so they can charge extra for the new 5/6 spd auto when it arrives.
Old Apr 10, 2004 | 01:18 PM
BHP's Avatar
BHP
Default Re: 6L80-E (Gene K)
One reason not to buy a 2005 C6. The 4L60/65E is a very primitive auto which requires many mods to make it shift correctly and withstand higher HP. Too bad GM will still be using this tranny in '05. We can only hope the 2006 car will have the 6-speed A6 transmission.
To 6L80-E
