I have seen many posts on the site that indicate that an order can be changed. When I spoke with my dealer he indicated that an order cannot be modified or cancelled once it is in the system. Can anbody confirm this?
You need to find out whether the order has entered the production system or not. If the order has not been placed into the production cycle you shoul dbe able to get changes done. Once it has been accepted and scheduled for production though you cannot change it.
That's great!! But just for clarification you can have an order number before it gets to production. It is a preliminary order number butit stays with the car all the way through even when it actually goes to production.
my dealer for soem unkown reason added the dreaded front tag as an option. when he faxed me the sheet... a week later i saw it and had them change it they said they did it in time and it woudnt affect anything
i think you get around 30days after order is placed i think as long as its not status 3000
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
My order was in the system and I changed my interior color and exterior color.... Im not sure if they allow it after your TPW or not... mine was changed before that... I think you should be able to....
