Info about the Reverse/ACC thing...
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I guess you would need to slam on the emergency brake put it in reverse and hit the button. Wow.
Originally Posted by Scissors
Neutral.
You probably won't know about a fuel leak until a fire starts. At that point you want your engine to run so you can get through traffic to pull over as quickly as possible.
You'll want to pull over as quickly as possible, and that may require having your engine running to punch through holes.
But no matter what, it's illegal to turn off your engine while moving.
Night Race Blue 427
Location: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Originally Posted by RedC6Coupe
Sure glad I've got an auto ordered. ![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
You have to put your's in park before it shuts off. Just think having to put it park at 70 mph.
![](/forums/images/ranks/11k.gif)
![](/forums/images/ranks/7k-10k.gif)
let's say on a long trip i pick up a beautiful hitch-hiker. against everyone heres better judgement, i let her drive. she drives awful, so i tell her to stop and let me drive. I WILL SHUT IT OFF BEFORE I EXIT(after mods) Otherwise i have to get her to put it in R. And since she shifts awful.....
Stock i risk her driving off without me if i leave it on.
OR, if she refuses to stop, how do i stop her? easiest way is to hit off, and i will re-wire it to take MY command.
:p:
:p:
Not to say that it couldn't happen tomorrow, but I've not ever yet had a situation in 47 years where I had to shut an engine off at 70 MPH. :ack
Originally Posted by Matt Gruber
happened to me on a brand new GM car. gas pedal got stuck. shut it off @70
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
Anybody know what happens if I want to put it in reverse, turn the engine off, then take it out of reverse? I frequently do this not when cleaning my car so I can push the car in neutral in order to clean the tires.
![](/forums/images/ranks/100-500.gif)
I wasn't fooling anyone 'sept myself...They knew :p
![](/forums/images/ranks/3k-4k.gif)
What happened to Neutral? ![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
Originally Posted by vetracer
Is there a rev limiter or would you be waiting for your new 400hp 6-liter to go ka-boom? :shocked:
#33
![](/forums/images/ranks/4k-5k.gif)
Originally Posted by Hernan
Say you are going 70 in a C5 and shut it off, now your steering wheel locks and you are still going 70. Weeeeeeeeeeee ![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
As far as the reverse thing, I would think that people would put it into first, press the button to shut it off, not realize that it did not shut off and then dump the clutch. Bang right into what ever is in front of them. Who was the rocket scientist that thought that one up?
#36
Originally Posted by yellow01
Agree with TedG ... we've spent the whole thread explaining why it is ok but haven't talked at all about why they even did it?
Once i did throw a car into N with the pedal stuck floored and it hit 8500 rpm. got towed home. only had 1 bent pushrod :p:
i did shut the key off first but it had no effect w/carb and turbo w/22 psi boost. i was at the end of a track, and THAT was a real emergency.
My c6 will have a kill switch which will double as an anti-theft switch in case my fob is stolen.
#37
☠☣☢ Semper Ebrius ☢☣☠
1. Allow the button to turn off the engine at any time.
2. Allow the button to turn off the engine only at a stop.
3. Allow the button to turn off the engine only while in 1st.
4. Allow the button to turn off the engine only while in Reverse.
5. Allow the button to turn off the engine only while in 1st or Reverse.
Let's look at all of these.
1. Accidentally hitting the button results in a very bad situation at freeway speeds. Also illegal to do so.
2. Why? Not as safe as 3, 4, and 5.
3. Makes sense as this is the safe way to park a manual, and forcing the issue may result in lower insurance rates, or may comply with future regulations.
4. Same as #3, but makes even more sense because reverse is a shorter gear and, thus, more resistant to movement. For both 3 and 4, lurching forward is only an issue if you're a bad enough driver to let the clutch out while the engine is running and the car in gear. This is the driver's fault, as the C6 requires you to push the clutch in to start the engine. If you don't want to risk hitting the car behind you, shift into neutral--just like everyone else.
5. Same as 3 and 4, but not as safe if people choose 1st and still has the same drawbacks.
So the answer as to why? Safety.
#38
Originally Posted by G35c6MT
I dont know if this has been discussed before, but shouldnt the Start Button on the Auto C6 work like the XLR?
How does it work in the XLR?
But I'll have an answer for you soon enough.
#39
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Seems to me that one of my early Z28's (maybe 73?) had this reverse shut off thing with the stock shifter. Just another place for aftermarket to jump in with a by-pass that costs about 80.00. CAGS, CLB....
#40
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
To shut off the engine while moving couldn't you just depress the clutch, shift car into reverse, leave clutch depressed, push button to shut off engine, brake to stop?
