Mathematically challenged....
Old Aug 24, 2004 | 04:15 PM
c64ken's Avatar
c64ken
8th Gear
More is better I choose 366
Old Aug 24, 2004 | 04:22 PM
Torchy2000's Avatar
Torchy2000
Originally Posted by TedG
Yes, but what is your favorite color?
Blue! No! Reeeeeedddddddd......
Old Aug 24, 2004 | 04:33 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
The real question here is which species of swallow has the most cupholders?
Old Aug 24, 2004 | 04:35 PM
TedG's Avatar
TedG
We are on the same page!
Old Aug 24, 2004 | 04:48 PM
bramwellt's Avatar
bramwellt
Originally Posted by VITIS
Just tell them it has a can of whoopass. They'll understand.
I prefer the term "big nuts" or "testicular fortitude". If that fails, just say "mine's bigger"
Old Aug 24, 2004 | 04:49 PM
bramwellt's Avatar
bramwellt
European or Arican?
Old Aug 24, 2004 | 04:54 PM
Torchy2000's Avatar
Torchy2000
Indeed, Sir, we are!
Old Aug 24, 2004 | 05:00 PM
TedG's Avatar
TedG
I have one of those!!
Old Aug 24, 2004 | 08:27 PM
Wolfbane's Avatar
Wolfbane
Originally Posted by lager99
What do you mean, an African or European Swallow?To begin with, I needed basic kinematic data on African and European swallow species.
South African Swallow
(Hirundo spilodera) European Swallow
(Hirundo rustica)
Although 47 of the 74 worldwide swallow species are found in Africa,1 only two species are named after the continent: the West African Swallow (Hirundo domicella) and the South African Swallow (Hirundo spilodera), also known as the South African Cave Swallow.
Since the range of the South African Swallow extends only as far north as Zaire,2 I felt fairly confident that this was the non-migratory African species referred to in previous discussions of the comparative and cooperative weight-bearing capabilities of African and European swallows.3
Kinematic data for both African species was difficult to find, but the Barn or European Swallow (Hirundo rustica) has been studied intensively, and kinematic data for that species was readily available.
It’s a simple question of weight ratiosA 54-year survey of 26,285 European Swallows captured and released by the Avian Demography Unit of the University of Capetown finds that the average adult European swallow has a wing length of 12.2 cm and a body mass of 20.3 grams.4
Because wing beat frequency and wing amplitude both scale with body mass,5 and flight kinematic data is available for at least 22 other bird species,6 it should be possible to estimate the frequency (f ) and amplitude (A) of the European Swallow by a comparison with similar species. With those two numbers, it will be possible to estimate airspeed (U).
In order to maintain airspeed velocity, a swallow needs to beat its wings forty-three times every second, right?Actually, wrong. By comparing the European Swallow with bird species of similar body mass, we can estimate that the swallow beats its wings 18 times a second with an amplitude of 18 cm:
Species Body mass Frequency Amplitude
Zebra Finch 13 g 27 Hz 11 cm
European Swallow 20 g ≈ 18 Hz? ≈ 18 cm?
Downy Woodpecker 27 g 14 Hz 29 cm
Budgerigar 34 g 14 Hz 15 cm
Note that even the tiny Zebra Finch flaps its wings no more than 27 times a second while cruising.
If we ignore body mass and look only at bird species with a similar wingspan, we can estimate an average frequency of 14 beats per second and an amplitude of 23 cm:
Species Wingspan Frequency Amplitude
Budgerigar 27 cm 14 Hz 15 cm
European Swallow ≈ 28–30 cm ≈ 14 Hz? ≈ 23 cm?
Downy Woodpecker 31 cm 14 Hz 29 cm
European Starling 35 cm 14 Hz 26 cm
By averaging all 6 values, we can estimate that an average European Swallow flies at cruising speed with a frequency of roughly 15 beats per second, and an amplitude of roughly 22 cm.
2 Observations:
1. The original question concerned a sparrow....not a swallow. Which we all know will alter the calculations significantly.
2. You have WAY to much time on your hands. I would suggest you get a new C6 as soon as possible to help fill up your day.
Old Aug 24, 2004 | 09:42 PM
Last Mango's Avatar
Last Mango
[QUOTE=Wolfbane]2 Observations:
Wolfbane:
I think most would agree: Discussing a swallower is far more interesting than a discussing a sparrower.
Old Aug 24, 2004 | 09:49 PM
Wolfbane's Avatar
Wolfbane
Agreed!
Old Aug 25, 2004 | 12:13 AM
LoneWarrior2552's Avatar
LoneWarrior2552
(Hirundo rustica)
lol
yea, its 364 (just incase it wasnt said enough)
Old Aug 25, 2004 | 12:16 AM
  #33
LoneWarrior2552
GO WITH BLACK!!!!!!!
--this is such a bizarre thread--
Old Aug 25, 2004 | 12:30 AM
  #34
vetracer's Avatar
vetracer
[QUOTE=...and as Mr. Wolfe eluded to earlier, I just wanted a number... I am often at the gas pump and asked by a NASCAR (no flame, I'm a HUGE fan) edition pick-up driver,
"Yeee--HAh Dude! Whot's she got in her??" (my C5). To which I reply, "an all aluminum Chevy 350", I then receive much praise and adoration.[/QUOTE]
I get asked almost daily by one of these guys about my '03 Silverado SS, "Yeee--Hah Dude! Whot's she got in her?? A Foor-Fiftee-Foor??
Then I have to explain that GM hasn't used the 454 since the C/K series pickup was replaced by the all new Silverado in August of 1998. Six years!!! I don't often explain it completely, let alone tell them that it is all wheel drive, 4:10 gears, ect. If you are that far behind, what's the point?
Oh, and Lager99, that was pretty damn funny
Old Aug 25, 2004 | 12:48 AM
  #35
TedG's Avatar
TedG
I have one of those also, and get asked that all the time.
Old Aug 25, 2004 | 08:00 AM
  #36
MYBLU71's Avatar
MYBLU71
We missed the question... What is the velocity, not beats per second to keep a constant speed... I am still waiting on the answer...
Old Aug 25, 2004 | 08:09 AM
  #37
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
I'm taking down all of your names, and reporting you to all of your bosses.
To Mathematically challenged....
Old Aug 25, 2004 | 11:08 AM
  #38
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Sorry, I wasn't finished yet. Here you go: Last month’s article on The Strouhal Number in Cruising Flight showed how simplified flight waveforms that graph amplitude versus wavelength can be useful for visualizing the Strouhal ratio (fA/U), a dimensionless parameter that tends to fall in the range of 0.2–0.4 during efficient cruising flight.
For a European Swallow flying with our estimated wingbeat amplitude of 24 cm, the predicted pattern of cruising flight ranges from a Strouhal number (St) of 0.2:
... to a less efficient 0.4:
If (St = 0.2) is accurate, then the cruising speed of the European Swallow would be roughly 16 meters per second (15 beats per second * 1.1 meters per beat). If (St = 0.4) is accurate, then the cruising speed of the European Swallow would be closer to 8 meters per second (15 beats per second * 0.55 meters per beat).
If we settle on an intermediate Strouhal value of 0.3:
We can estimate the airspeed of the European Swallow to be roughly 11 meters per second (15 beats per second * 0.73 meters per beat).
Airspeed can also be predicted using a published formula. By inverting this midpoint Strouhal ratio of 0.3 (fA/U ≈ 0.3), Graham K. Taylor et al. show that as a rule of thumb, the speed of a flying animal is roughly 3 times frequency times amplitude (U ≈ 3fA).5
We now need only plug in the numbers:
U ≈ 3fA
f ≈ 15 (beats per second)
A ≈ 0.22 (meters per beat)
U ≈ 3*15*0.22 ≈ 9.9
... to estimate that the airspeed velocity of an unladen European Swallow is 10 meters per second.
Old Aug 25, 2004 | 11:17 AM
  #39
MYBLU71's Avatar
MYBLU71
Sorry Jason, thanks for the info... that answers one of the age old questions... now for the meaning of life...
Old Aug 25, 2004 | 11:26 AM
  #40
lager99's Avatar
lager99
St. Jude Donor '06
And you thought you had one up on me.
