Check Engine Light Came On
Old Sep 5, 2004 | 05:12 PM
abrimberry's Avatar
abrimberry
Cruise-In II Veteran
Default Check Engine Light Came On
Anyone know how to access the error codes? Thanks.
Old Sep 5, 2004 | 06:07 PM
hb_cpa's Avatar
hb_cpa
St. Jude Contributor
Check your gas cap. It might not be on correctly
Old Sep 5, 2004 | 10:38 PM
TooManyIDs's Avatar
TooManyIDs
Good question. On the C5
  • Key to start, but leave the engine off
  • Press and hold the Options key
  • Press the Fuel key four times
  • That will scroll all systems.
  • Press 1 (Fuel), 2, 3, or 4, to enter manual mode
  • In manual mode, use 3 to move forward, 4 to move backwards through each system
  • 2 to move down, within a specific system, 1 to move back up
  • Reset key will clear codes (press and hold)
  • 5 (English/Metric) to exit diagnostic mode
Now having said all that, you should find that in the tech tips along with several code values and their meanings.
Does all this work on a C6? No clue, let us know.
Old Sep 5, 2004 | 11:13 PM
MosportGreen66's Avatar
MosportGreen66
Not sure what the problem is on your car but at the NCRS National they had to put GM's Silver C6 Conv. back onto there truck because they were having technical problems and the car wasn't even on, it was parked.
Old Sep 6, 2004 | 12:46 AM
BRCC's Avatar
BRCC
I asked this about 2 months ago, being I could get this info on my C5 I wondered if it was available on the C6. Never got a response.
I have had my C6 for 12 days and still do not know the answer, being the system does not operate the same I have not figured out what sequence you can get the DIC to display any DTC info. Additionally I do not know what codes the system can display if it can be done by the user. Someplace I did see there were 81 trouble codes for the C6. Unless we have a GM tech out there we might not know for a while if this option is even available on the C6.
Old Sep 6, 2004 | 12:48 AM
abrimberry's Avatar
abrimberry
Already tried that. I was hoping it worked as it did on the C5. No luck.
Unscrewed it and put it back on. Check engine light didn't go off. Used the nifty On Star remote diagnositic service. They suggested checking the gas cap as well. They said it could take up to 7 days for the check engine light to go off. We'll see. I'll update this thread with the end result.
Thanks for the ideas.
Old Sep 6, 2004 | 12:58 AM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
You can probably use the 'ol low tech solution to clear the code.........disconnect the battery for 10 minutes, reconnect, and see if it comes back. .
Old Sep 6, 2004 | 12:00 PM
Thud's Avatar
Thud
"Check Engine" came on in my truck, too. I checked the engine, it was still there. The light's been lit for about 4 years now.
Old Sep 6, 2004 | 12:04 PM
vettewntd's Avatar
vettewntd
Old Sep 6, 2004 | 01:00 PM
JoesC5's Avatar
JoesC5
I don't have a clue as to how you pull up the codes on A C6. It seems all mfgs like to change everything when they change models. On last year's model you rotated the **** to the right to function, this years models you rotate the same **** to the left to function. Same damn **** and function, they just like to change things so they can claim it's new and improved. You might want to go to http://corvettemechanic.com and see if he can help you.
Old Sep 6, 2004 | 02:56 PM
JoesC5's Avatar
JoesC5
Do you ever read a post before you respond? He asked for info on accessing the codes, not clearing them.
Old Sep 6, 2004 | 05:36 PM
Barely Legal's Avatar
Barely Legal
Scroll throug the DIC and it will tell you. The C6 does have a DIC right?
Old Sep 6, 2004 | 10:16 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
YOu cant access the codes in a C6.. you need whats called a tech tool... dealer only....
Old Sep 6, 2004 | 10:17 PM
Thud's Avatar
Thud
You have got to be kidding!
Old Sep 6, 2004 | 10:31 PM
TooManyIDs's Avatar
TooManyIDs
I wonder if the scanning software, like EASE, will display codes?
Old Sep 7, 2004 | 10:27 AM
LS WON's Avatar
LS WON
Computers computers better buy that fine 69 427 big block instead at least those are more accessible and easier to work on and don't depreciate.
To Check Engine Light Came On
