down shifting- cost?
Old Sep 26, 2004 | 08:45 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by Lazerwolfe
I think it turned into a knowledge contest after awhile.
Yes, the thread did stray a little.
Old Sep 26, 2004 | 09:07 PM
Popeye's Avatar
Popeye
I have never had a brake job done on any of my cars. You know what that means, don't you?
And I'm not talking low mileage either: 230k, 180K, 260k, 120k miles.
I always try to let the engine do as much braking for me as possible, whether I downshift or not. Of course, if you are performance driving, downshifting (heel & toe) is a necessity. If you are one of those drivers who races light to light then brakes hard, your brakes probably won't last long.
Old Sep 27, 2004 | 02:23 PM
LS WON's Avatar
LS WON
Originally Posted by Rocketblock
It's your car... wear out what you want and pay for it!!!
Just buy an automatic and you won't have to worry about mis shifts or down shifting or wear on clutches.
Old Sep 27, 2004 | 02:47 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
$3.50
Old Sep 27, 2004 | 02:57 PM
Last Mango's Avatar
Last Mango
Always good for a mid day chuckle.
Old Sep 27, 2004 | 02:58 PM
LS WON's Avatar
LS WON
It has been over 14 years that I have changed my brakes and I love to downshift. My car has 196,000 on it.
Old Sep 27, 2004 | 03:03 PM
flood's Avatar
flood
use both methods. Moderation is the key to long life
Old Sep 27, 2004 | 03:24 PM
Vette_DD's Avatar
Vette_DD
Thanks. I'm going to use both, again, with moderation.
Old Sep 27, 2004 | 03:25 PM
LS WON's Avatar
LS WON
Variety is the spice of life
Old Sep 27, 2004 | 03:42 PM
willisit's Avatar
willisit
Life is too short to worry about such things.
"Drive it like ya stole it".
Old Sep 27, 2004 | 03:49 PM
LS WON's Avatar
LS WON
Old Sep 27, 2004 | 03:58 PM
Thud's Avatar
Thud
Originally Posted by SWCDuke
If you double clutch, the gearbox will last forever.
If you learn how to heel and toe double clutch you can downshift as you brake. This technique must be mastered if you ever wish to become good at racing or hot lapping race tracks, and it also makes you a much better and more astute street driver.
If you're the type that flips it into neutral and brakes when a light in front of you turns red, you should stick to automatics.
Duke
Why do you need to be in gear for a red light?
Old Sep 27, 2004 | 04:01 PM
  #33
sorka's Avatar
sorka
The cost? About a quart on a 2001
Seriously, why brake with two wheels when you can brake with 4?
Old Sep 27, 2004 | 04:06 PM
  #34
Thud's Avatar
Thud
Ummmm... remind me what exactly do 4-wheel disc brakes do again?
Old Sep 27, 2004 | 04:08 PM
  #35
LS WON's Avatar
LS WON
They cause you wear n tear.
Old Sep 27, 2004 | 04:09 PM
  #36
Thud's Avatar
Thud
Good to know. I'll try to avoid using the brakes from now on.
By the way, if you don't ever start the engine, you will save wear and tear on the oil.
Old Sep 27, 2004 | 04:14 PM
  #37
LS WON's Avatar
LS WON
Ditto for your turn signals and windows going up and down will wear out power window switches. Power locks now that is tough.
Old Sep 27, 2004 | 04:36 PM
  #38
docrings1's Avatar
docrings1
C6 FAQ Master
Engine braking is relatively cheap stopping power -- using the vacuum of the engine to slow down the car.
But, the thread turns to "heel'n'toe" because manual transmission drivers have to engage the clutch to downshift. Since a mismatched flywheel speed and clutch speed can cause *some* premature wear to the clutch (vice brake pads); therefore, the heel'n'toe advice is well taken...
