Does anyone know the proper position for the drivers seat? To get my 6'4" frame comfortable in the C6 I need to move the seat all the way back and move the recline all the way back. This is not the position I am currently used to in my BMW. Is this the normal position most people use in their Corvettes?
I had a track training tape with my Miata...they said to sit back, extend the arms, and have the steering wheel right at your wrist level. However, for some reason, I do find my self reclining more in the Vette. Maybe some pros could pipe in....
1. Most of us need a Corvette seat as low as it will go, but keep the seat bottom cushion tiled back as much as comfortable, to help keep you in the seat.
2. Put seat back tilt in middle position.
3. Move seat forward until you can just touch the floor under the brake pedal with your foot, without sliding your butt forward in the seat. This ensures you can get full brake pedal travel if needed.
4. Move steering wheel up/down until with hands at 3/9 position, your hands are equal or slightly below your shoulders.
5. Move steering wheel in/out until your elbows are a 90' bend, then move steering wheel slightly further forward.
6. Make minor adjustments to seat back angle as needed for comfort, or to make up for a steering wheel that does not telescope.
At first this technique made me feel too close to the wheel, but after a while it seems great for both street driving and road course driving.
Raising the driver's seat to a high position also has obvious advantages for vision around the car - the higher you sit, the better you see, especially in city traffic.
Teenage hoons seem to be convinced that straight arms and finger-tip steering is the way to go. Lazy drivers believe they can somehow steer a car with only the left hand on the wheel and the right arm resting on the window sill.
Once test drove a Miata...Nice little sports car, but I felt like a sardine! (6'2") Porsche Boxster also a bit cramped. BMW's are spacious, and C5 and C6 are good for me.
First thing I do is adjust the seat recline as far forward (vertical) as possible. This position will give my head maximum support against the headrest.
I'm 6-4 and the first thing I did when I got to the dealer was to see if I could fit in the C6. No prblem there. I also like the seat back more upright which I adjusted and still no problem. I was thinking if I needed more head room, I would have ordered the transparent roof but didn't needed to do that. Plenty of headroom with the standard top. I've learned after having a sun roof, unless the roof is down, I don't particularly like having the sun shining in my face putting me in squint mode.
