This has happened three times now but I'm still not sure if it's an actual problem of if I'm just over sensitive to the possibility of something going wrong.
When I start the car in the morning it seems as if the radio / nav unit freezes up. The radio is playing what ever channel it was left on but it does not respond to any of the buttons, hard or touch screen. I can't turn it off or adjust the volume. But here's the kicker. If I shut off the ignition, open and close the door to shut down the power, and start it back up everything is just fine. No problems from then on. This has only happened in the morning. When I start the car at the end of the day there is never a problem.
