Skip Shift Eliminator Problem
Old Oct 6, 2004 | 06:19 PM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
Default Skip Shift Eliminator Problem
Has anyone heard or had a problem with the Cags bypass causing the car to overheat?
We had a customer state that when the bypass was installed the car hit 260 degrees and uninstalled it and it worked fine.
Any input would be nice.
Paul
__________________
Your #1 Resource For Corvette Parts and Corvette Accessories
1748 W Business Center Dr.
Orange, CA 92867
Phone:714.630.6396 / 888.737.8388
Shop By Model:
C8 Corvette Parts & Accessories
C7 Corvette Parts & Accessories
C6 Corvette Parts & Accessories
C5 Corvette Parts & Accessories
Old Oct 6, 2004 | 07:17 PM
mikeyc6's Avatar
mikeyc6
Paul
Must have been something unrelated or some coincidence. I don't see how inserting a resistor that the PCM can't even detect could cause overheating. I have the CAGS eliminator on mine; no sign of any overheating problem.
Mike
Old Oct 6, 2004 | 07:39 PM
Matt Gruber's Avatar
Matt Gruber
Paul
That had to be plugged into the wrong harness
Old Oct 6, 2004 | 08:56 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Do you mean "coolant by-pass" ?
Old Oct 6, 2004 | 11:45 PM
jackcasa's Avatar
jackcasa
I've had a "CAGS defeat" on my '98 for seven years and there has never been an overheating problem.
Old Oct 7, 2004 | 12:25 AM
Quick Brick's Avatar
Quick Brick
I bet he plugged it in the wrong socket
Old Oct 8, 2004 | 07:19 AM
C8-Vette's Avatar
C8-Vette
I plugged the resistor(2200 ohms .5 watts) into mine 2 day ago--no overheating problem--Plug is located on tranny DRIVERS SIDE-only plug on that side of tranny- The pass side has 2 plugs-one is probably to keep you from going into reverse accidently-Have no idea what the other does-
Old Oct 8, 2004 | 08:10 AM
jschindler's Avatar
jschindler
Mike
Old Oct 8, 2004 | 11:49 AM
Hoonose's Avatar
Hoonose
Originally Posted by c6vette
I plugged the resistor(2200 ohms .05 watts) into mine 2 day ago--no overheating problem--Plug is located on tranny DRIVERS SIDE-only plug on that side of tranny- The pass side has 2 plugs-one is probably to keep you from going into reverse accidently-Have no idea what the other does-
Should be 1/2 watt = 0.5watt!
Just checking!
Old Oct 8, 2004 | 06:17 PM
C8-Vette's Avatar
C8-Vette
Just checking!
You're right .05 is incorrect -my typo- .5 (1/2) is correct
SORRY
Old Oct 8, 2004 | 06:23 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Old Oct 8, 2004 | 10:04 PM
vetracer's Avatar
vetracer
No problem with mine
Old Oct 8, 2004 | 11:40 PM
Shylor's Avatar
Shylor
GM has already stated that an aftermarket bypass can cause incorrect voltages in the BCM and a damaged BCM. Not sure if this would cause the engine to overheat or not.
Old Oct 9, 2004 | 01:20 AM
DudeWheresMyVette's Avatar
DudeWheresMyVette
From: NYC / Naples, FL C5 under construction! Arancio Atlas (Lamborghini Metallic Orange) comming soon! :)
Very strange....
Old Oct 9, 2004 | 01:39 AM
FASTRNU's Avatar
FASTRNU
I used them on three of the C5s I have owned, never a problem with any of them.
To Skip Shift Eliminator Problem
