MP3s
Old Oct 15, 2004 | 09:50 PM
Jay_Davis's Avatar
Jay_Davis
Default MP3s
This is a bit off topic, but since it directly relates to my impending C6, maybe someone can help.
Right now, in my C5, I have 13 CDs loaded. Since the C6 only takes 6, I'll need to convert stuff to MP3s. But the catch is that there are a lot of choices when converting to MP3s. Various codecs, options, compression ratios, etc. This is the first time I'm mucking with MP3s. I understand the function and the math of it all, but that doesn't equate to what it really sounds like.
So, what's the best codec to use and how far can you compress things before it becomes noticable? Obviously, this is for use in the C6 environment (as opposed, lets say, to using them in a sound studio with $50,000 speakers).
As a side question for those of you already using MP3s in your C6, how does the C6 determine play order of the MP3s on a disk? Alphabetical, order on the disk, etc. I've seen some people having problems with play order on some cars using various burning software, although no one has reported any issues yet with the C6 (other than the track 10+ issue).
I've got some tracks to burn and I figure I might as well get a head start.
Old Oct 15, 2004 | 10:05 PM
sorka's Avatar
sorka
I'm super picky about sound quality. I can hear the difference between 256K and 320K....but just barely(320K is the maximum bitrate). I used LAME and most importantly, VBR (variable bit rate). With VBR you pick a minimum and maximum bitrate. I chose 128K to 320K. I also chose the highest quality. The size seems to average out to what 192K CBR was, but without reduced sound quality. I fit about between 8 and 10 cds per disc and have 100% cd quality as far as my ears can tell using Sony MDR-V6 headphones for reference.
Old Oct 15, 2004 | 10:21 PM
Lakelander's Avatar
Lakelander
Veteran: Marine Corps
I burned my MP3's using Itunes. I basically used the highest quality (192K) in the preference menu and they sound real nice. Play order is the order burned onto the MP3 (unless you play in random mode). There are additional features of the C6's MP3 players abilities such a folders, playlists, sessions, files but I haven't gotten that far yet. For now just MP3 files on a CD, load & play.
Old Oct 15, 2004 | 10:25 PM
Motor City Vette's Avatar
Motor City Vette
I usually use VBR between 128k and 320k
Old Oct 16, 2004 | 01:06 AM
c2jones's Avatar
c2jones
Interesting Content here.
I'll make sure to save this item for future use.
I'll need it.
Thanks!
Old Oct 16, 2004 | 03:10 PM
Jay_Davis's Avatar
Jay_Davis
Thanks, its a good starting point. I'll have to experiment a bit but it looks like I shouldn't bother with anything under 128K and probably 160K to 192K may be optimum.
I have read a few things that indicate that using VBR really doesn't make much difference. I guess I'll have to play with that too. Some people also claim an audible difference between different encoders, especially at higher compression rates, so that's another thing to mess with.
Something to keep my mind off this waiting. Then I need to figure out what's going to be track 1 of the first CD I put in the car when it arrives.
Old Oct 16, 2004 | 03:32 PM
JockItch's Avatar
JockItch
Believe me, VBR MP3's make a difference. I can tell the difference between a regular 192kbps MP3 file and a song encoded in VBR at about the same file size. It's just that it usually takes a set of good ears and higher end equipment. With my Sony CD3000 headphones, I can differentiate the two.
Old Oct 16, 2004 | 04:14 PM
Vette_DD's Avatar
Vette_DD
Remember to play a "full" CD with plenty of tracks (first time only) before playing an MP3 with fewer tracks. Someone else in this forum couldn't play the upper tracks on the CD because they played the MP3 first.
Old Oct 16, 2004 | 09:31 PM
fdxpilot's Avatar
fdxpilot
So, what's the best codec to use and how far can you compress things before it becomes noticable? Obviously, this is for use in the C6 environment (as opposed, lets say, to using them in a sound studio with $50,000 speakers).I've got some tracks to burn and I figure I might as well get a head start.
I use Musicmatch or EAC to rip my CDs to MP3s, usually at 192K. Supposedly, 128K is equivalent to CD quality, but I can hear a difference from 128K to 192K on my home equipment.
Old Oct 16, 2004 | 10:10 PM
Jay_Davis's Avatar
Jay_Davis
I would hope that they have fixed that problem by now. But I guess I'm better off being safe. If I remember right, you need 50 (or more) tracks and start playing the last track first. Is that what everyone remembers?
Old Oct 17, 2004 | 10:33 PM
docrings1's Avatar
docrings1
C6 FAQ Master
Use the free ripper "Audiograbber" to convert whole CD's to MP3 albums:
http://www.audiograbber.com-us.net/
download HERE
you will also download a small file, the actual Encoder file:
download the "Lame" encoder HERE and unzip it into your install folder to get the higher encoding rates (128, 160, 192, etc.)
It works great!!!! And it's free!
I use 192 for ripping so I can use them at home (need higher bitrate for better sound system) and in the car (128 is fine there with road noise, etc., but why have two different files?)
Be sure and organize the folders by Artist --> Album --> Track#-Title
(You need to add the track number to the title to keep them in their original album order, or the computer will "alphabetize them". Make sure the artist and album are not part of the song name... they get WAY too long! The artist name and album will be encoded in the song with an internal song tag that displays while playing the MP3.
Good luck!
Doc Rings
Old Oct 18, 2004 | 12:58 AM
Spasa-Pasa's Avatar
Spasa-Pasa
will the mp3 player in the C6 be able to read the tags (both id3v1 and id3v2)? I'm just asking because i have seen mp3 discman's that don't display this info.
Old Oct 18, 2004 | 10:26 AM
Jay_Davis's Avatar
Jay_Davis
download HERE
Good luck!
Doc Rings
If you put atist/album in folders, does it go from folder to folder in alphabetical order?
To MP3s
