Custom Audio Install <repost>
Sorry for the repost - someone mentioned I should start a new thread for this.
Some pictures from my install. Here's what I did:
- Replaced 10" doors with Focal K2P's and JL 150x2 amp
- Added rear 8.25" Focal Polyglass subs and 500W JL monoblock amp
- Audio Control ES and LC6 equalizer and level converter
- JVC 12-disk CD/MP3 changer wired to FM modulator (between seats)
- Custom enclosures, grilles, and rack/shelf unit
I really didn't realize how good car audio could be until now - it's truly unbelievable. The install does raise the entire rear deck to level with the front lip, but the targa roof still stows in its carrier, since we used the storage wells behind the wheel wells as part of the sub enclosures. Do NOT try this at home unless you're a pro. Took high end custom installer 5 days and a lot of debug. Chevy's aftermarket changer coming out in a few months should address part of the reason I started this project.
Originally Posted by webdzynes
Very nice job! How did you seal in the speakers in the back to be air tight with the new floor?
Sounds like you have the midbass and subbass covered-what about the mids and highs-are the stock speakers OK for you? I'm curious what the center channel speaker is. I would think a good 1" dome tweeter would work well in each door-one you could cross over to get into the upper mid range area. I've had high systems in previous cars and there sound can be spectacular. I worry about the intigrated electronics in cars like the C6. Sometimes those monitoring computers just don't understaand what's going-you've added a significant power drain on the battery. Keep us informed and the install looks great.
Originally Posted by 7 OUT
How much did it cost?
The price range of car audio equipment is large, and the sound quality isn't proportional to the $ invested until you get past a certain threshold. My problem was that I upgraded the bass first, and then it overwhelmed the Bose mids and fronts. Then I upgraded the fronts, but they needed a new amp... Etc, etc, etc. I started having flashbacks of my first wife ;-). Anyhow, I ended up upgrading the whole system. Unfortunately, there's just no cheap way to shortcut a car audio system upgrade since the whole thing is only as good as its weakest component.
I don't want to rag too much on Chevy and Bose, because car sound is one of those things that's not very important to some. Chevy could have come out with a higher end package that still wouldn't have sounded that much better. Also, to be fair, the installer I worked with specializes in Porsches - and they do the same thing to the Porsche factory sound - rip it out, and put in the good stuff. They recommend getting base sound for Porsches since it's coming out anyhow.
What are Focal K2P's (maybe that's your mids and highs?) If you have great sound, no weird DIC messages-warnings and no alternator whine-you'll get your money's worth with years of listening enjoyment. What kind of music you like?
Originally Posted by TedG
See I told you it would be better to post your own thread.
I will ask again, did you leave the stock head unit in? Is that why the level converter?
Interesting they went with the raised deck design, I have played with that idea myself. Now go upgrade your Big3 wires! It will be the best and cheapest upgrade you can make for your electrical system which will now need it with those amps you added.
If I ever get my freak'in C6 I will post step by step pics of my install since I will be doing it myself.
Nice system herschel.
Focal K2P's are a 2-way system that replace the door speakers:
http://www.focal-america.com/catalog...er/165k2p.html
Focal Polyglass Subs, 209mm:
http://www.focal-america.com/catalog...glass/21v2.htm
Stock head unit stayed in - Nomad is right. Also, the new deck allowed for major wiring upgrades to everything. Lots of 4 gauge running around under there. Some 0 gauge. That stuff is ridiculous.
There's no way I'd ever buy a car that couldn't fit golf clubs in the back ;-). 911 barely squeezes into the rear "seat", and you better not have a 45" driver. I can still get two sets of clubs in the back of the C6 (carry bags only!).
Here's Rod's website:
http://www.caraudioinnovations.com/
Click on "installations" to see some of his work.
Great stuff! I wonder what it would take to convince my wife to let me do this.
1) How does this setup effect/integrate with the Nav? Can you still use the touch screen presets?
2) How do you access the equalizer? Is it behind you?
The equalizer is under the deck with the amps. It is calibrated at installation using their calibration system. Thereafter, you have the normal tone controls on the Nav. Plus, they added a separate control under the dash for the bass amp if you really wanted to rumble.
Nav unit works the same. I have the CD changer set to 88.1 FM. The 12 FM presets still work, but one of them is dedicated to the changer.
