I have a set of the BMW lifting pads...they fit perfectly (snap right in the slots underneath)...you can leave them in (hard to see unless your on your hands and knees looking underneath). They're round in appearance and they extend about 3/4 inch below the frame (not very visible)...but they do the job nicely. Just use a flat edge knife/flat tip screwdriver to remove them...most people just leave them in. I also have the "puck" version, but you put those in when just before the lift and you have to remove them after you're finished. With the BMW pads just put them in and forget about them...they're ready when you're ready to jack or lift.
Go to your local BMW dealer and ask for the black plastic lifting pads for a 325 series (2002/2003 model)...they're about $6 each.
I am confused on this jacking pad thing. The owner's manual describes the lift points when using a floor jack (not the same points that the dealer uses with the big lift). It says nothing about pack pads, and the jacking points appear to me to be as adequate as on other cars, and I can't see where any damage should result in using a standard jack with no pad. So, I don't quite understand the need for the pads. Can someone fill me in?
Just another way to get your $$$$$ for every little thing there is a giant $$$$ attached to it because of the NAME Corvette has always been like that.
Manual shows the inboard jack points and does say "Be sure to place a block or pad between jack and vehicle" which is not to be confused with the hockey puck style pads being banter about here...this would be the normal lift pads as you can see in this image lift pads
The jack points that the pucks are for the the out board jack points which actually are lift sites along the perimeter chassis rail just below the doors and which have a slot thus the puck design...I have a sissor jack with pads and thus do not need the pucks and yes you could damage the painted running boards without the pads or pucks.
Hope this helps
Michael
I read the thread that discusses using BMW jacking pads for a C6. Has anyone used them and do they hold in place or are there better alternatives?
You can use actual hockey pucks with eye bolts cut to size and threaded in the center. Simple as that and they lock in place and work great. Make sure your eye bolts are no larger than the slots they go into, especially width-wise. Saves a lot of money over the store bought versions.
