Problem number two
Old Nov 16, 2004 | 05:16 PM
jabez's Avatar
jabez
Default Problem number two
On the DIC I keep getting "right rear tire over inflated"
I check the tires and they are ok...around 32-35 lbs but the message keep popping up. Is there a way to clear it? Is is there something wrong with one of my sensors?
Old Nov 16, 2004 | 05:24 PM
Alx1rl's Avatar
Alx1rl
Default odd.
Are you checking the tire when they are hot or cold, when they are hot they expand and the psi gets lower (but not the true psi), which may seem normal to you. Check the tires before you go for a drive in the morning while they are still cold that the true temperture.
If its normal then it might be a sensor, but play with it for a minute, take out 3 psi and see if its still going off. Take out 10 psi and see if its still going off. If it is then the sensors messed up, just inflate back to what you want it to be at and schedule a appt. with the dealer.
Old Nov 16, 2004 | 05:36 PM
StealthS's Avatar
StealthS
Actually, as a tire heats up, the tire pressure increases, not decreases. The air expands (or wants too but cannot) a lot more than the tire when heated so the pressure rises. That makes more sense with your warning - you measure the pressure when cold and all seems fine, but when you drive a while the air pressure increases (apparently too much) and causes high pressure warning.
Outside temperature makes a big difference here, too.
However, if you see the warning and immediately stop the car and check the pressure with a tire gauge, you should get the same reading on the gauge as the car told you. If not, you either have a bad tire gauge or the pressure senser in the tire is not reading correctly.
Old Nov 16, 2004 | 05:43 PM
yellow01's Avatar
yellow01
What does the sensor in the DIC say as far as the acutal pressure value? (not withstanding the high pressure error).
If it is showing as higher than your manual guage reads, two things could be happening.
The sensor could be bad or it needs to be reset/retrained. I don't know if the C6 retraining procedure is the same as the C5 but the procedure for C5s is listed in the tech tips section.
I don't have a C6 so maybe I'm completely wrong, but that's how I'd approach the same problem on my C5.
Old Nov 16, 2004 | 05:46 PM
Rocketman50's Avatar
Rocketman50
Check your gage...I've had them that were incorrect.
Old Nov 16, 2004 | 06:01 PM
Alx1rl's Avatar
Alx1rl
Thats what i meant... thanks!
Old Nov 16, 2004 | 06:11 PM
Vette_DD's Avatar
Vette_DD
The owner's manual (p 5-61) says that a warning message will appear on the DIC if a tire is underinflated (falls below 24 psi) or overinflated (above 42 psi). Even if you're running 35 psi, that's 7 psi under the limit. Sounds like a sensor might be bad in that tire. Don't think you'll see more than 3 or 4 psi added or subtracted for cold vs hot tires.
Old Nov 16, 2004 | 06:37 PM
c6nut's Avatar
c6nut
Go back to the dealer. They can reset them.
Old Nov 16, 2004 | 07:16 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
The C5 had a tire training mode and I would think the C6 does also.
This sounds like a bad sensor but I would do the tire training first before dismounting the tire and replacing the sensor.
Old Nov 16, 2004 | 07:44 PM
jabez's Avatar
jabez
I can take this car to any Chevy dealer right?
There is a dealer about two miles from work and i can just drop it off before I head out to work.
Old Nov 16, 2004 | 07:45 PM
docrings1's Avatar
docrings1
C6 FAQ Master
Sounds like a great topic for the FAQ, if you post the "how-to's" of "tire training" in this thread or a new thread...
Old Nov 16, 2004 | 07:46 PM
jabez's Avatar
jabez
It says left side rear 32 lb
right side rear 50 lb
Old Nov 16, 2004 | 10:18 PM
TedG's Avatar
TedG
First of all make sure your tire gauge is working properly and set your inflation to 30 cold just like the sticker says. Then once you have checked the inflation, see what the DIC says the pressure is. It should be 30. If not then the sensor needs to be be replaced. Do not over inflate or under inflate.
Old Nov 16, 2004 | 10:59 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
I didn't even know it reported that. Cool.
Old Nov 16, 2004 | 11:05 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Unlike the C5,No more owner "tire training" on the C6...Requires a new $450 Kent-Moore analizer tool to relearn the sensors
Old Nov 17, 2004 | 01:56 AM
LS WON's Avatar
LS WON
Default Use Nitrogen instead of plain air
Supposedly the pressures are suppose to be the same hot or cold. I tested this and when the tires with nitrogen got warmed up that is exactlly what they did went from cold to warmer
Old Nov 17, 2004 | 01:58 AM
LS WON's Avatar
LS WON
Default Nitrolgen is not suppose to expand
You can add air to a Nitrogen filled tire it will just be more air as opposed to Nitrogen.
To Problem number two
Old Nov 17, 2004 | 02:02 AM
LS WON's Avatar
LS WON
Default Not all Chevy dealerships are authorized to work or service Corvettes
If they haven't received the training on the C-6, it is my understanding that they cannot sell or service corvettes because none of the techs or sales people are certified on the C-6.
Old Nov 17, 2004 | 09:43 PM
jabez's Avatar
jabez
Whats "tire training"?
Old Nov 19, 2004 | 01:13 PM
StealthS's Avatar
StealthS
Default A Nitrogen-Filled Tire? Why?
I don't really understand what you are saying here, but did you know that air is more than 78% pure Nitrogen? Alomost all the rest of air is Oxygen (20%) which weighs and behaves almost the same as Nitrogen. So I doubt you will get any measurable difference or perfomance between an air-filled tire and a Nitrogen-filled tire.
I have never heard of a Nitrogen-only-filled tire. Is this common practice? If so, can someone tell me why? It won't be much different that air, so I don't understand...
