Anybody experience humidity "fog" inside the front light enclosure (like if a seal were broken)? I picked up my new DSOM C6 on a VERY foggy FL night and noticed a couple of hours after driving through a lot of rain that the inside of the light casing had a small amount of "fog" (about 20%).
Thanks for your help
Rick
I just went to look at the C6 for the first time tonight in a local dealer. They had 3 or 4 of them there. A dark blue one was sitting out in the parking lot with the headlights about 50 percent fogged. This was remarkable to me, and I asked the salesperson about it. He nonchalantly commented that it was normal. Personally, I just don't see how that can be good to have your headlights fogged with moisture.
Whether we like it or not, these lights are designed to allow condensation to form on the inner lens surface. According to GM, the moisture will burn off within 30 minutes of headlight use and has no effect on the brightness. Every dealer has received an FAQ sheet explaining this.
I don't know why the lights are designed like this, but it is normal and every C6 will form condensation under the headlight lenses.
1. 100% sealed, which will eventually leak and, when it does, will result in permanent moisture buildup. This also makes aiming of the headlights with a flush-monted unit nearly impossible.
2. Vented which prevents permanent moisture buildup and is the most durable over the long run.
GM took option 2. Just as all other manufacturers with projection lenses behind clear covers do.
I went to dinner at my parents today, and without any prompting, he told me that a good friend of his went to look at the new Corvette. The one comment my father's friend had was that the lights were completely fogged up. He got the "it's normal" explanation from the dealer, and then expressed his dismay and left. My father's friend is an accomplished engineer and program manager at a defense firm, thus being very familiar with problems like this. When a person like him is put off, I would think you may be dealing with a public perception problem, regardless of whether function is impaired or not. People aren't diggin' it.
He'll probably end up buying the car anyway. Ironically, my father mentioned that they should be backfilling them with nitrogen.
Outgassing is a product of heat affecting the plastic that comprises the bulb socket. If the heat is decreased, the outgassing may decrease or be eliminated. The heat required to produce outgassing of a plastic is dependent upon the type of plastic used in the socket. (Outgassing of plastic is normal, that is why the inside of your windshield gets a film that is more prevalent during warm months. The plastic I/P top panel outgasses.)
The turn signal and high beam bulbs should burn at around 200+ degrees F. As for the outgassing from the plastic, it depends on the plastic.
Some manufacturers have recalled cars to place a resistor inline to decrease the voltage to the bulbs, which decreases their temperature, thus, decreasing outgassing.
As for a nitrogen filled headlamp assembly, it would be ideal. However, I would hate to ever replace one. It would have to be sealed a lot better, have sealed glass areas where the bulbs enter in the rear, and then be manufactured to take the shocks and vibration a headlamp assembly takes when driving down a road (especially, those roads in the northern states). I can conceive of no reason why it cannot be done, I just can't fathom what the price would be for manufacturing...and replacement.
Scissors, You are 110% correct - anyone who has ever owned an 80's or 90's Ford product knows this from experience when they "sealed" their headlamp modules and used a plug-in halogen socket w/ gasket - they took a rock, etc. and then the lens "leaked" air and moisture formed, sometimes water even puddled
The easy "fix" was to vent it yourself w/ a small drill bit to the bottom of the module and let the water drain out
I have seen some "C5r" exposed lamp kits that seemed to have vents of some sort, built in, hmmmm
