Visor Clip FIX
Old Nov 29, 2004 | 10:01 PM
Lawman31's Avatar
Lawman31
Default Visor Clip FIX
Some of us were having trouble with the visors not staying in their clips. Mine was the passenger side, easy 5 minute fix and you get to play with fire too.
I unscrewed my clip and unplugged the wire to the light, on the passenger side. I then took the clip into my kitchen, turned on the stove, heated up the area in question just enough to make it pliable, don't set it on fire, just get it hot. Remove from fire and press down on counter top in a way so that your clip area will be smaller. Hold in place for about 30 seconds or so until it cools a bit and put it back in your car.
I did mine about 3 days ago and it is holding like a champ. When heating up this piece, don't put it directly in the flame; hold it about an inch above for about 5-10 seconds at a time to make sure you don't melt it.
I hope this helps you guys, and gals.
Kevin.
Old Nov 29, 2004 | 10:48 PM
SA734's Avatar
SA734
Kevin, didn't your wife tell you to keep the Corvette out of the kitchen!?
Old Nov 29, 2004 | 11:58 PM
Alex Levy's Avatar
Alex Levy
Kevin.
So that thing on the passenger side is a Light next to the visor clip? How do you turn it on?
Old Nov 30, 2004 | 01:10 AM
Lawman31's Avatar
Lawman31
The light provides ambient lighting on the radio area and comes on automatically at night.
Kevin.
Old Nov 30, 2004 | 01:12 AM
Lawman31's Avatar
Lawman31
What? Are you kidding? My wife doesn't even know we have a kitchen. I didn't even know if the stove would work, one turn and PRESTO, I had fire.
KEvin.
Old Nov 30, 2004 | 01:13 AM
DudeWheresMyVette's Avatar
DudeWheresMyVette
From: NYC / Naples, FL C5 under construction! Arancio Atlas (Lamborghini Metallic Orange) comming soon! :)
Does the wife wonder the same? jk
Old Nov 30, 2004 | 11:07 AM
Lawman31's Avatar
Lawman31
If you rub the light at just the right moment, it will turn on. My wife LOVES to turn on my light.
Kevin.
Old Nov 30, 2004 | 01:28 PM
archtop's Avatar
archtop
Kevin.
Thanks great fix.I'll use my heat gun and a C-clamp so I can adjust pressure.
Old Nov 30, 2004 | 02:20 PM
Lawman31's Avatar
Lawman31
Make sure to remove it from the car, a heat gun may work fine, but don't do it while it is in the car.
Windshield could crack, fabric could singe etc... I'm sure you had planned to remove it, but just wanted to make sure.
Old Nov 30, 2004 | 11:03 PM
archtop's Avatar
archtop
Thanks again!What a great fix!!Torx t-15 to remove(I unhooked the LED light from socket) brought it to my shop,used a spring clamp ,applied heat slowly with my heat gun,let cool.Reinstall ,tight like it was made that way.It was driving me bats before ,everytime I hit a bump it bounced off.
Old Nov 30, 2004 | 11:59 PM
Lawman31's Avatar
Lawman31
Probably the easiest fix on the car, I hope everyone with this problem reads this thread.
I am happy for you.
Kevin.
To Visor Clip FIX
