Something Very Odd
Old Nov 30, 2004 | 03:31 PM
VITIS's Avatar
VITIS
Active Streak: 90 Days
St. Jude Donor '15-'16,'18,'19-'20
Default Something Very Odd
When I first picked up my car a noticed how hot the center consol was compared to other cars. I even put a recording thermometer in the consol to see what the temperature was _ 130F I was concerned about putting things like CD's in there that the heat might damage. Well, one day a while back I became aware that the heat was gone! There is just a little warmth around the shifter but everything else is completely cool. It's an A4 with about 3000 miles when I noticed the difference. Anyone have any ideas as to what could cause the change?
Old Nov 30, 2004 | 03:38 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Did you leave the oven on?
Old Nov 30, 2004 | 03:59 PM
VITIS's Avatar
VITIS
Maybe turned it off, but left the fridge door open.
Old Nov 30, 2004 | 04:00 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default OH No Mr Jason
Jason, Do you drink heavily when on-line?
Old Nov 30, 2004 | 04:07 PM
Boozman's Avatar
Boozman
Don't feel strange my C5 would feel like and oven and when I picked up my C6 it was the same but now after 2100 miles it doesn't get that hot anymore strange things are happening down there.
Old Nov 30, 2004 | 04:09 PM
curvesman's Avatar
curvesman
C2 of the Year Finalist - Unmodified 2020
The sawdust in the tranny shifted
Old Nov 30, 2004 | 04:16 PM
StanNH's Avatar
StanNH
Mine did exactly the same thing. It was very warm when I first got it but now, with 1,000+ miles on it, it's not warm at all. I'm not sure if something has burned off or if the colder weather is a factor.
Old Nov 30, 2004 | 04:22 PM
pyroc6vette's Avatar
pyroc6vette
Default No problem here
My silver C6 has ~500 miles and the center console has never been even close to being warm...and yes I do drive it occassionally over 55 MPH. I just assumed GM fixed the problem that I had read on the Forum. Mine is a 6sp.
Old Nov 30, 2004 | 04:29 PM
Vette_DD's Avatar
Vette_DD
Maybe something DROPPED OFF.
With several people experiencing the same thing, it MAY be the weather.
Old Nov 30, 2004 | 04:53 PM
roscoe118's Avatar
roscoe118
My thoughts exactly. Is has gotten a bit cooler throughout the country in the last month
Old Nov 30, 2004 | 04:55 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Is the heating in the c6 Forced hot water or Electric?
Old Nov 30, 2004 | 04:59 PM
s420merc's Avatar
s420merc
Not the Heat is Radiant base heat hehe
Old Nov 30, 2004 | 05:34 PM
yellow01's Avatar
yellow01
This is a hair brained explanation but maybe there is significantly more friction on an un-broken-in tranny hence more heat generation in the early going. As things get worn less friction generates less heat... I dunno.
Old Nov 30, 2004 | 05:50 PM
ny10522's Avatar
ny10522
First 520 miles: no heat from center exhaust. I do hear an intermittant clicking noise from behind the right side of the diriver's seat when going over some bumps. Anyone experience this?
Old Nov 30, 2004 | 06:47 PM
Lawman31's Avatar
Lawman31
Adjust the little rubber bumpers under your rear hatch lid, this should eliminate the loose rear hatch.
Old Nov 30, 2004 | 11:43 PM
VITIS's Avatar
VITIS
Weather hadn't cooled much when I noticed the difference. That plus I'm not sure what would be in the center tunnel that would produce less heat with breakin.
BTW, you take great car photos. Ever think of another career and moving to a warmer climate?
Old Dec 1, 2004 | 12:25 AM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
lager, I thought you told me your real name was Horatio Bernardo?
To Something Very Odd
Old Dec 1, 2004 | 02:37 AM
shopdog's Avatar
shopdog
I was complaining about the tunnel heat back when the outside air temp was in the 80s, but now that it is down in the 40s, not so much. I expect the hot tunnel will return next summer (unless I install one of Elite Engineering's ceramic coated plates first).
Old Dec 1, 2004 | 08:13 AM
StanNH's Avatar
StanNH
Thanks! Ask me again in February.
Old Dec 1, 2004 | 10:45 AM
Xx1QuIcKcOiNhOlDeRxx's Avatar
I think I may have an explanation (maybe, maybe not)...
Do u guys have this problem with the windows rolled down? because if, so, the slight vacuum effect by doing this causes the air travelling under the car, around where the shifter is, to want to pull up, and into th cabin..since this air is heated via the manifold/cats, it'll tend to heat the area around the shifter...with the windows raised, you don't have this effect...
now, since the temps are cooler, most of you are driving w/ the windows up, thus the problem hasn't been happening as much..
try driving with the windows down, and then up to see if i'm right...
