Any tips on avoiding a "fishtail"?
with the cold tires mention. You have to gradually accelerate in a car like a Vette, especially in cold weather. You just cant give it all its got and expect to go straight even if you are pointing the car straight. especially with runflats
with the cold tires mention. You have to gradually accelerate in a car like a Vette, especially in cold weather. You just cant give it all its got and expect to go straight even if you are pointing the car straight. especially with runflatsI concur!
My 2001 C5 was never a handful with Active Handling on, and I had to be pretty stupid in Competitive Driving mode for Active Handling not to catch me.
I haven't yet probed the C6's limits in this regard. I wonder if they loosened up Active Handling a little too much considering tires and power? Or are you folks all goofing around in arctic conditions?
.Jinx
When the weather turns colder, the tires will slip more easily (both front and back). That applies to braking and acceleration.
Drive carefully until you understand how the car will behave with different road and weather conditions. Use an empty parking lot if you need to practice.
Today was Lesson One.
The combination of cold tires and road, 400hp, and a newbie vette owner, in my humble opinion cause this.
I'm doing the mall parking lot on a Sunday morning. Its scary to learn in traffic.
Michael
A few beginner tips. The worst thing you can do is white knuckle it when you start to fishtail. Be calm (not loose, not tight) on the wheel and smooth. With everything you do, do it almost in slow motion. Don't jerk the wheel. Let up on the gas slowly and steadily. The key to coming out of it smoothly is to modulate the gas so that you time the point where the rear wheels grab and regain traction to a point at which the car is pointing in the right direction.
Then when it grabs, make sure your hands are loose on the wheel! If your hands are loose and it grabs traction with the car pointed the right way, your steering wheel will jitter real quick left and right a couple of times and the car will track straight as an arrow. Trying to correct at that last moment, or even trying to hold the wheel from moving, is the biggest newbie mistake and it'll put you in the ditch on the side of the road more times than not. If you are fishing left and right, don't pop your foot off the gas while you are sliding sideways at a 45 degree angle. Correct a little and let the rear slip back and when the car is almost straight, lift smoothly off the gas while you loosen your grip on the wheel. With a little practice, it'll work every time.
YMMV of course, and do this at your own risk.
Of course, if active handling comes into the picture, it will have more say than you as to when the rear wheels regain traction.Mike
