Easy Entry/Exit Differences Between A4/M6?
Old Dec 16, 2004 | 08:55 PM
Superstar555's Avatar
Superstar555
Default Easy Entry/Exit Differences Between A4/M6?
Is there a difference in the way "Easy Exit" and "Easy Entry" work between the auto and manual?
Old Dec 16, 2004 | 09:12 PM
Vette_DD's Avatar
Vette_DD
Yes.
For easy exit, you must have the parking brake set (and the gearshift in reverse) with the manual before using the button or opening the door will set the easy exit. With the auto, you only have to have the shifter in PARK for either to work.
Old Dec 16, 2004 | 10:05 PM
vetracer's Avatar
vetracer
And when you get back in, if you have the manual you must push the memory recall button on the door, whereas the auto can be programmed to return the seat to driving position without pushing anything.
Old Dec 17, 2004 | 02:32 AM
shopdog's Avatar
shopdog
Well, you have to push the start button.
To Easy Entry/Exit Differences Between A4/M6?
