Programable garage door opener?
Old Dec 25, 2004 | 11:52 PM
greengo's Avatar
greengo
Default Programable garage door opener?
I have programed my C6 to open the primary gaarage door for my C6 but have been unable to program the second garage door to open. Kinda weird because the second door is the one that usually opens from a block away and still works great with the opener that is in my truck...It just wont works as opener #2 in the vette. Any ideas?
Old Dec 25, 2004 | 11:55 PM
TedG's Avatar
TedG
Originally Posted by greengo
I have programed my C6 to open the primary gaarage door for my CG but have been unable to program the second garage door to open. Kinda weird because the second door is the one that usually opens from a block away and still works great with the opener that is in my truck...It just wont works as opener #2 in the vette. Any ideas?
Mine works fine for 3 different doors. More info is needed, different brands? Different models?
Old Dec 26, 2004 | 12:00 AM
greengo's Avatar
greengo
Same brand door openers on both..same models exactly. Me thinks Im making a programming error on door opener #2. When I push door 1 the lite above the one is solid..when I push door 2 the lite above it blinks
Old Dec 26, 2004 | 12:55 AM
Hoonose's Avatar
Hoonose
Make sure one doesn't have a rolling code.
Probably not since you say they're the same.
When you do the setup, only hold down the two outside ONCE to start the process.
Don't hold these down again, when trying to program the 2nd.
Otherwise you've erased the 1st!
Old Dec 26, 2004 | 01:01 PM
TedG's Avatar
TedG
That's a programming problem. I did the same thing on the Escalade when I was trying to program it.
Old Dec 26, 2004 | 04:27 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Thanks for the great info
I was over the inlaws last night and they have a mercades and a lexus.
He has had this problem since he got the lexus.
So i did what you said
programmed the mercades than drove it out on the street away from the lexus.
then programmed the lexus and THEY BOTH WORKED
Now maybe my wife will stop giving me a hard time for spending too much time on the forum!
Old Dec 26, 2004 | 05:46 PM
Convert14's Avatar
Convert14
I still can't get mine to work, I am now, however reluntantly, ready to turn this challenge over to the middle son. Kid is always shaming me. Guess I am an easy target.
Old Dec 26, 2004 | 05:47 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Third Option
Try putting programming it with third button.
Old Dec 26, 2004 | 07:29 PM
greengo's Avatar
greengo
I have tried everything in the manual...step by step and door #2 still will not respond.......The vette opener gives all the proper indications that it has remembered the code but it still wont open garage door #2..........soooooooooo.... I put the old double garage door opener on the visor......I've given up!
Old Dec 26, 2004 | 07:39 PM
Hoonose's Avatar
Hoonose
Start over.
Erase all by holding the 2 outside buttons down...
Program door #2 first, and then see if you can get door #1.
Old Dec 26, 2004 | 11:17 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
I have the same problem on my new Yukon.
Old Dec 27, 2004 | 12:50 AM
smook's Avatar
smook
Alien waves.... Alien waves....
Funny, one day an aircraft was flying low (not normal where I live) and our garage door opened.
Must be alien's.
GOOD LUCK.
-Bill.
(at least you have warranty!! AHAHAHAH)
Old Dec 27, 2004 | 01:19 AM
chazzf's Avatar
chazzf
Default Here's a trick
Try borrowing a neighbors remote (make sure he has same garage door opener). Use it to "teach" your remote, then retry the programming. And no, you won't be able to open his door.
Old Dec 27, 2004 | 10:54 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Emi
Originally Posted by smook
Alien waves.... Alien waves....Funny, one day an aircraft was flying low (not normal where I live) and our garage door opened. Must be alien's. GOOD LUCK. -Bill. (at least you have warranty!! AHAHAHAH)
EMI, Electro Magnetic Interference. It happens. Went out one day and my trunk was popped open
Old Dec 27, 2004 | 10:59 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Emi
Must be alien's.
GOOD LUCK.
-Bill.
Electro Magnetic Interference. It happens. Noticed my trunk popped open a few weeks ago – same thing.
Old Dec 27, 2004 | 03:34 PM
MASTR CMDR's Avatar
MASTR CMDR
6th Gear
Hi! I am trying to find out if the rolling code door opener will work on the new c6 buttons. since I have not received my new c6 yet, I wanted to update my openers, that are 10 years old, before the vette arrives. I'm reading here that the c6 cannot open this setup. My question is what do you vette owners do to keep people from using a code copier from sitting near by coping the codes? thanks for any input.
Old Dec 27, 2004 | 03:58 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
The Home Link on the C6 will work with rolling code.
Old Dec 27, 2004 | 04:05 PM
Boozman's Avatar
Boozman
Had the same problem started over and now it works
Old Dec 28, 2004 | 01:18 AM
MASTR CMDR's Avatar
MASTR CMDR
6th Gear
Thanks, for the replies. I think I'll buy a IDRIVE door closer tomorrow at lowes and install it.
To Programable garage door opener?
